Have you inadvertently programmed your microwave for "autostart"?
Your model microwave has the ability to be programmed to go on at any given time of the day/night, even when you're not home so that you can have a defrosted and cooked meal waiting for you when you get in.
I know that if you hit the 30 sec button or the minute button when your micro is programmed to autostart it will tell you the time that it's programmed to autostart or the amount of time that's left for it continue cooking.
Have you tried unplugging it for a few minutes?
This should clear it's memory and then all you'll have to do is set the time on the regular clock if you want.
Here's where you can download and read your owners manual for further instructions on how to use the autostart feature and everything else:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
1) Press
the "Stop" button on the microwave to
reset the digital display to the clock setting.
2) Push the
"Clock" button once. Locate the "Hour" button and
press it once for each hour of time. For example, if the current time
is 5:15 p.m., press the Hour button five times.
3 )Press
the "Minute" button to set the second half of the time. For
the example above, you would press the Minute button 15 times to set
a time of 5:15 p.m.
4)Push the Clock button to save the time setting. Check the time on the microwave's digital display.
