I cannot get the HDMI Input 3 to work. THe HDMI Input 1 works. I am trying to swtich from the Componet Video Input 3 to the HDMI Input 3
Posted by delljack on
Heath Moyer
  • 767 Answers
Sometimes you have to push the HDMI button a few times to get it to switch from the HDMI 1, HDMI 2, or HDMI 3. Try pushing the remote buttons in this sequence to get it to switch. Be sure your HDMI cable is properly installed and pushed in alll the way.
Posted on Dec 26, 2009
I have connected to my 2311: HDMI 1: Oppo BDP 83 HDMI 2: Denon DVD 1740 HDMI 3: Apple Mac Mini Issue: The Mac Mini works fine and I have audio and video through the receiver, but for the BD and DVD only...
hi,
You have to check the digital audio assignment of you AVR for HDMI 1 and HDMI 2. There is three options for the digital audio for HDMI 1 and HDMI 2. You can set it as optical ,coaxil, or the HDMI itself. In you receiver the assignment may be in optical input or in coaxial input for the two HDMI inputs.
1. Go to the system setup
2. Select input setup
3.Select input assignment.
4. Select all the three input ,you are using as HDMI
ok
Apr 11, 2011 | Denon AVR-2311 Receiver
When trying to connect the ps3 using the supplied analog cables nothing appears on the screen it is as if there is no output from the unit. Prior to this the unit was hooked up using the hdmi cable. Any...
make sure all connections are secure. and that the a/v cables are plugged in to a input jack and the colors match ie yellow to yellow for video red to red and white to white for sound they and also be sure the right input selection is selected on tv. this setup will not work in the componet input jacks.
if this helps please rate this answer so it can help others thank you and good luck
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
RX-V465 output HDMI 1 will work but HDMI 2-4 won't, also when I hook up Wii via rca to receiver only get sound no picture.
This receiver has only one HDMI output, but 4 HDMI inputs. If some inputs don't work, try connecting the equipment (DVD for example) to HDMI input which works with other equipment....
For the RCA (composite) video input - it won't work, because this receiver don't have any video processing circuit.
So HDMI input video goes to HDMI outout connector.
Composite (RCA) video input goes to Composite outout and no other video output.
S-video input goes only to s-video output.
Dec 20, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Ps3 won't transmit on tv, tv works ps3 is running, checked all cords
You need to check and make sure that you are trying to view the PS3's output on the proper channel or input on your TV. If you need to scroll through every channel and input.
If that doesn't work try replacing the A/V or HDMI cables. If it still doesn't work you may need to send it to Sony and have it replaced. The video output section of the console may be bad or not functioning correctly.
If you have a friend with a PS3 try to see if they will bring their's over and let you test it out. If their PS3 won't display then it's something wrong with the wires or the TV.
Dec 16, 2009 | Sony Playstation 3 (PS3) Console
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
HDMI connection???
Hi Greg,
Again, if you have a high definition dish box with HDMI output,and a dvd player with HDMI output,please connect them both directly to your TV HDMI inputs.
When watching TV(dishnetwork box).remember to switch the HDMI video inputs.
Same as your DVD player,you need to switch it under your TV video input.
solutiondoct
May 28, 2008 | Denon AVR-2807 Receiver
Cant get HDMI input to work
Hello Kman69,
You have one of two most likely problem.
(1) You have a defective HDMI board. This is most likely the case with your set.
(2) You may need to do a software upgrade. This is not common with the Sony, but i have done my fair share of upgrade.
I have the board in stock, just in case you need it. The software is available (free) and is very easy to do.
Best regards
circuitcity
Feb 29, 2008 | Sony KDF-E42A10 42 in. LCD Television
48 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
