Maytag SAV5710 Top Load Washer Logo
Posted on Nov 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag SAV5710 washer fills and timer stops before agitating. The timer does not advance. Manually moving timer to any other function does not work either. Tub is still full of water. Before this occurred the washer would fill, agitate, and stop before spinning/draining occasionally. Lid switch was replaced but nothing changed.
  • Chris Huff
    Chris Huff Nov 15, 2017
    If not lid switch, timer would be likely.
Chris Huff
Level 3:
Top Expert:
  • Maytag Master 6,289 Answers
  • Posted on Nov 15, 2017
Chris Huff
Maytag Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2019882
Points
74913
Most likely lid switch has failed.
5 Related Answers
Anonymous
  • 319 Answers
  • Posted on Jan 04, 2008
SOURCE: maytag washer, lat9606aae only works in delicate cycle and hand washable
Replace it
Anonymous
  • 1028 Answers
  • Posted on May 01, 2008
SOURCE: Amana NAV2335AWW During the agitation cycle
suspect noisy brake not a major concern but not a pleasant noise to listen to..best not try repairing yourself ..believe that may be a maytag version if so brake spring can be dangerous to release without proper tools
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Nov 18, 2008
SOURCE: maytag mav6200aww removing inner tub
curious as to why you would be removing hte inner tub??? possibly to repalace the main seal??? if thats the case the directions are in the newseal kit. but htere should be a starlike plastice hub seal that will need to be unscrewed that is whats holding down the tub
Robert Siegel
  • 36 Answers
  • Posted on Jan 02, 2009
SOURCE: maytag washer won't agitate
your transmission is no good and needs to be replaced
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Jan 03, 2009
SOURCE: maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Centennial series stops agitatimg
Usually a top loader will not agitate until the fill sensor is satisfied. If the water has shut off, and is up at the desired level, the fill sensor has done part of it's job. Check the connections there, and at the timer. It may just be a loose connection.
Maytag A512 clothes washer will not agitate, lid switch ok, will spin and pump water out, timer does not advance once washer is filled. It makes no motor sound once filled. If I manually advance the...
With the motor not coming on it sounds to me like the timer is going to be the problem and the contact in the timer for the motor to rotate in the agitate direction is burnt out. The part number for the timer is 206230 The timer could be ordered from your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwanger.com
repairclinic.com
GENE..OldTech2332
MAV6250AWW Alantis washer Fills Agitates but does not drain rinse or spin unless I spin the knob while in the off position to the desired function
I would suspect the timer needs replaced since it works if you manually advance it. If this helps, please rate my answer. Thank you.
1helpful
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
1helpful
LAV3600AAW Maytag Top Loading Washer
check your house drain make sure it is above water line in tub
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
