2000 Jaguar S-Type Logo
Posted on Dec 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Everytime I lock the car using the key fob, about 30 seconds later the alarm sounds but the lights do not flash and the horn does not sound. Only when I unlock the car will it go off. I have disconnected battery to and manually locked all doors.
Johnny Brown
Level 3:
  • Jaguar Master 5,763 Answers
  • Posted on Dec 26, 2009
Johnny    Brown
Jaguar Master
Level 3:
Answers
5763
Questions
0
Helped
3164305
Points
20432
You may have a bad door switch, theres a switch on the drivers door lock, when door is unlocked with fob or key the switch is activeated to shut alarm down,the lock moves to hit switch with key or fob,so if the switch is bad it will not shut down alarm, i would start there,door panel has to be remove,then latch has to be remove to get to switch, then test with a meter see if it opens and closes the connection, hope this helps.
Anonymous
Level 2:
Sergeant:
  • Expert 191 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
191
Questions
0
Helped
63252
Points
584
Check the car battery itself a failing battery will cause issues with the alarm control system,and also replace the battery in the key fob(remote)
How to turn off the factory alarm on a 2000 Dodge Ram 3500?
I don't know about turning the alarm system off completely, but if you are trying to get it to stop chirping the horn and flashing the lights when locking/unlocking the doors, I found the following in the Ram 3500 Owner's Manual:
To lock the doors: Press and release the LOCK button on the transmitter to lock all doors. If the ignition is OFF, when the doors are locked, the parking lights will flash on once and the horn will chirp once.
The horn chirp feature will be shipped from the assembly plants activated. If desired this feature can be disabled by using the following procedure:
1. Perform this operation while standing outside the vehicle.
2. Press and hold the LOCK button on a programmed (i.e. functional) key fob.
3. Continue to hold the LOCK button, wait at least 4 seconds, but no longer than 10 seconds, then press and hold the PANIC button. Release both buttons at the same time.
4. To reactivate this feature, repeat the above steps.
Vehicles will be shipped from the assembly plants with the park lamp flash feature activated. If desired, this feature can be disabled by using the following procedure:
2. Press and hold the UNLOCK button on a programmed (i.e. functional) key fob.
3. Continue to hold the UNLOCK button, wait at least 4 seconds, but no longer than 10 seconds, then press and hold the LOCK button. Release both buttons at the same time.
tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
I assume the factory alarm was somehow bypassed when they installed the remote start is there a way I can make the factory alarm work when the doors are opened without key,?
To arm content theft alarm.
1. Open the door.
2. Lock the door with the power door lock switch or
the remote keyless entry transmitter. The
SECURITY light should flash.
3. Close all doors. The SECURITY light should go off
after approximately 30 seconds. The alarm is not
armed until the SECURITY light goes off.
If a locked door is opened without the key or the remote keyless entry transmitter, the alarm will go off. The headlamps and parking lamps will flash for two minutes, and the horn will sound for 30 seconds, then will turn off to save the battery power.
How do I get my alarm system to chirp instead of beep when it goes off or when I lock my doors with the remote entry key fob?
Check to see if your vehicle honks when you press the "lock" button on your key fob. Press the "lock" button multiple times in a row. Many devices won't beep unless you double-tap the button after locking. If the horn doesn't honk, but the lights flash, your chirp feature is probably disabled.
Use your keyless fob and ignition key to enable the audible chirp. The process varies considerably on different makes and models. You must usually consult your owner's manual, a dealership or the alarm manufacturer for the correct process.
Why does my remote start just make the car horn beep and security lights flash but doesnt start?
it sounds like security start relay malfunction ,check and or change out relay.
How to turn off the pro alarm
I would start by replacing the FOB. Sounds to like the electronics inside it are bad. The only reason the horns would go off is if you hit the panic button. There is a slight chance the receiver is bad. But Fobs are cheaper to replace than the receivers. If you have two FOBs and they both react the same, then replace the receiver. Or just ditch the system. The keys (in the door locks) should still activate the alarm system.
2helpful
Kia rio key fob power lock/alarm problem
if the lights flash when you hit the panic button but the horn does not beep, then the alarm horn is bad. Vehicle has a second horn just for the alarm
2001 TA WS6 - Horn and key fob not working
Horn problem is either bad horns or failed clockspring behind steering wheel which is the connection for the airbag and horn buttons.
2006 PT Cruiser alarm sounds without
now sometimes this happens to let you know that one of the doors are open
check your doors
this is the only thing i can think of altho you have most likely checked it lol
also lock the car with the key
you don't want it to get stolen
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
