Question about Bose Cinemate Digital Home Theater System Speaker
Trying to connect to LG 60 inch plasma. no output
Posted by sschweyer on
  • sschweyer Dec 26, 2009
    no option on the BOSE cinemate unit to use this type of optical output cable. Also don't have that type of cable. Can I get an adapter and that type of cable at electronics store? system only comes with RSA (red/white) and only has hookups for that type of cable
Anonymous
    New Friend:
Hi..
I connected my Bose Cinemate system to my 50 inch LG LCDTV with a receiver (vintage Sherwood.)
My newer Sony receiver did not have the audio output ports needed.
Works great.
texasbaglady2
Posted on Jan 02, 2010
Ginko
  • Bose Master
  • 19,396 Answers
Hi.
You need to connect the Bose using the Optical Audio output from TV to Bose main unit (kind of square shaped connector), and not using the RCA inputs on TV.
The picture below is an LG back panel, the optical audio connector is at the lower side of I/O connections at the back of TV, on some model the location of connector may be different.
Posted on Dec 26, 2009
  • Ginko
    Ginko Dec 26, 2009
    Hi.
    You cannot use any adapter.
    The optical cable must be purchased separately.
    Since the Cinemate has very few connectors, the only thing you can do is connecting monitor out from TV. Connecting the Cinemate to TV inputs is of no use, you need an output.
    The only alternative is purchasing an expensive bose control module.
    Try the monitor out or any audio output from TV first.
  • Ginko
    Ginko Dec 26, 2009
    I wanted to add that the Bose Cinematic mark I, like yours (newer ones have optical in) had been designed to connect to TVs that have an analog out (White/Red). Most modern TVs do not have analog audio out, but only optical.
    Here a discussion on the topic:
    BOSE Cinemate Experience
1helpful
I have an LG 60 inch plasma model 60PV450 that has no picture but does have sound
It is probably the backlight inverter board. These are common problems on all LCD and Plasma units that use fluorescent backlighting.
My plasma tv just started having water colors flashing on top and bottom?
Contact the authorized service centre for LG. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
L have a lg plasma 60 inch tv but the sreen its creaked
There is no other way than replacing the screen.
1helpful
I how a 60 inch tv that need screws for the base but don't know what size screws
CALL LG CUSTOMER SERVICE AND THEN GO TO HOME DEPOT ETC.
THEY ARE GOING TO BE STANDARD BOLTS.
1helpful
I have a 6 mo old lg 60 inch plasma tv. 2- 1" greyish vertical lines running down just off left of center.
start hunting down your warrenty info before you do anything. If you try to repair own your own you will void it at this point
I NEED A TABLE TOP STAND FOR 50 - 60 INCH PLASMA
I will suggest you check ebay.com or amazon.com for the table top for your 50-60 inch plasma. Any o the two sites will provide you what you need.
3helpful
I have a 50 inch LG plasma tv, not sure of the modal number. But I cannot how to change the output setting to PCM sound that I may use a sound bar connected to the optical port.
The optical output is always on.......you will see that the cable is lit up at the end when you plug it in........you may have to set your sound bar for the optical input though........do you have that manual?
Can my 60 inch lg lasma be fixed
Yes,what wrong with ur 60" LG Plasma tv,but not if ur screen panel is broken or damage,because replacing the screen panel it cost the same as a new tv,might even more after the labors.The screen panel's are 90% of the tv that why.It also limited producced by the tv industries.
Connecting pc to lg 32 inche
you have not mention the model of lg 32"   what i suggest is lower the resolution of your hp pc tp 800 by 600  and gradualy increase the res to get the picture which matches the plasma hope this will solve your problem
Bose Cinemate Digital Home Theater System Speaker Logo
Top Bose Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
