Canon PowerShot S1 IS Digital Camera Logo
Question about Canon PowerShot S1 IS Digital Camera
It keeps turning off and saying the batterys need changing. Even when i put new batterys in it still turns off. help
Posted by simon199 on
Anonymous
  • 178 Answers
It must mean the digital camera battery life is end! You should buy a new one.ha ha~
Posted on May 12, 2010
Why does my camera keep saying battery exhausted even when I change the batteries?
If batteries leaked in the camera the connections IN the camera may be dirty. Putting in a new battery takes care of the battery connection but not the camera connections. This is why it is very important to take out batteries when you are done taking photos. When you want to shoot again you put the batteries back in and set the time and date. You MAY be able to clean the connections with a pencil eraser. If you use a pencil eraser please blow out the dust from the eraser. If you are positive the camera then I cannot help you here.
15helpful
2answers
Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
My Samsung Digimax 420 keeps saying low battery!
Check that you are using the correct type of batteries and that they are rechageable as i found i had a similer problem when using just normal non recargeable
Samsung digimax s700
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
2answers
Lense does not close
sir, ur camera lens mechanically stucked or gears problum ,this is repairable
Change Batteries....?
Ok.. did you guys try a reset? Just remove the batteries, wait for 60 seconds then put them back in.. that should reset the camera..
2answers
Canon A95 "Change Batteries" problem!
I have this problem as well. I thought it was a problem with my NiMH batteries. So, I bought a volt meter to make sure the batteries worked. I have 8 AA NiMH batteries. I charged them all up and tested them with the volt meter. They were all good to go. However, no matter what I put in the camera one of two things happens:
1. I get the "change batteries" message.
2. I don't get the message, but the next time I check the camera (a few days later), one of them is totally drained.
Something is very wrong and I plan on contacting Canon.
You need to use 2100 mAH or 2300 mAh rechargeable batteries - alkaline batteries will not maintain the high level of power required.
Keeps saying to change batteries
It occurred lately with reloadable NiMh-batteries.
When I put in some alkaline batteries I had no problem.
I cleaned the contact surfaces of the NiMh-batteries and the contact surfaces in the camera. Up till now I have had no problems.
grt.
Aad
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
