Fastener Type
Torque Spec.
Main cap bots
95-105 ft.-lbs.
Connecting rod bolts
40-45 ft.-lbs
45-50 ft.-lbs
for Boss 351C
Cylinder head bolts (follow factory torque sequence)
105 ft.-lbs.
125 ft.-lbs for
Boss 351C
Rocker arms (non-adjustable)
18-22 ft.-lbs.
5/16" Intake manifold bolts
21-25 ft.-lbs.
3/8" Intake manifold bolts
28-33 ft.-lbs.
Oil pump bolt
25 ft.-lbs.
Cam bolts
40-45 ft.-lbs.
Cam thrust plate bolts
9-12 ft.-lbs.
Harmonic damper bolt
70-90 ft.-lbs.
Flywheel/ flexplate bolts
75-85 ft.-lbs.
Pressure plate bolts
35 ft.-lbs.
Front cover bolts
12-18 ft.-lbsI hope this helps you and please rate this
SOURCE: What is the torque sequence for the head bolts on
On the cleveland i would always take the even setting torque all around the head and........... then the x patteron evenly out from front to back............Make sure to use torque wrench at equal intarviles each time to specific torque required....Hope this helps.
SOURCE: ford 351 cleveland
OK. I hope this information is what you looking for.
And hope work for you. Thank you for use fixya.
SOURCE: need schematic for vacuum lines on 351 clevland
try auto zone.com they have had most of what i have had to search for [email protected] good luck..DALE
SOURCE: engine wiring Diagram for a 351 cleveland
have you gotten an answer for the wiring on your 82 ford bronco w a 351C? i have the same problem putting a 351C into my 81 ford bronco
You'll have to be a little more specific, as there are many areas that require proper torque when assembling engines, and engine parts.
