Question about Intel Motherboard
Where to connect cable "speaker" on mainboard MSI K9A2GM
Where do I connect speaker on mainboard MSI K9A2GM.
The cable (black and red twinned) is loose and i don´t know where to put it?
Cabel POWER LED E is also just hanging. Is it supposted to be connected somewhere?
The same for cable AC´97??
Posted by christina_li on
Brett Duxbury
  • Intel Master
  • 4,290 Answers
5 Related Answers
Anonymous
  • 2351 Answers
SOURCE: Mother Board connection
Go to the site below. Its a manual for the 800/i65GV group. Go to page 67 and zoom in. You'll get a nice look where everything goes. Two rows of pins. Upper row and bottom row. Real close to each other. Do not place connectors up to down. Connect only left to right.
The reset connector has two pins. One will be white or black. These are - grounds. So connect it to the bottom row onto the most right two pins. Moving to your left. Skip one pin. Take the Power Switch a two pin connector. Remember Black & White is ground & ground goes to your right for both rows of Mb pins.
http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4p800/e1324_p4p800.pdf
Go to IDE_LED next. Its the last two pins towards your most left of the bottom row of pins. Move to the upper row & the power LED. Same as the bottom row keping the grounds to your right. Lastly is the speaker. Its connector holds four pins but you only use two. One in each end.
Good luck & please vote....
Posted on Dec 22, 2007
Anonymous
  • 3 Answers
SOURCE: CONNECTION MOTHER BOARD MSI 7043
connection to the motherboard as per your query is not critical. you can do trial and error method, since an LED connected in reverse will not damage it, but just show no glow. so just reverse again, if it glows then its okay if still no glow then the LED is dead. Anyway, if you need the manual you can download from this link: http://global.msi.com.tw/index.php?func=downloadfile&dno=3825&type=manual
Posted on Oct 14, 2008
Anonymous
  • 298 Answers
SOURCE: number codes for giving connections to HDD led,Power led, Reset SW & Power SW to motherboard
Those are really tricky and always vary from motherboard to motherboard.
without the exact model no one will be able to tell you exactly. But I'd recommend that you start out with the power (pw) plug and try trial and error. The only ones really necessary are the pw and reset. the only 2 that are polarity sensitive are the HDD light and pw led.
Posted on Apr 18, 2009
computerscot
  • 166 Answers
SOURCE: I don´t have the foxconn motherboard manual "661m08"
Most mobo's have the connection points printed on them. Use a strong flashlight and look for some pins that have the following words printed near them (PW or PWR, RS or RST, HDD LED, etc) They should all be grouped together in the same corner of the mobo. Have you tried googling the motherboad name to find a manual? I have done that on a few occasions and got lucky.
Posted on May 01, 2009
Anonymous
  • 285 Answers
SOURCE: Need picture of mother board for Emachine C2825
I've built a PC myself, each connector had text on it to say what it was and one arrow on it in relief, don't know wether that indicated plus or minus anymore.
Anyway, I recommend you just plug them in, and try to boot the PC. If it doesn't boot, switch the Power SW connector around, then it should boot. Do the same with the LED connectors, and it should work just fine!
Good luck,
Yannick.
Posted on Jul 13, 2009
Wiring diagram for ms 7069
Hello here is the homepage:
http://www.nec-computers.com/support2/pib.asp?mode=default&platform=platform_callisto_g_mt
This mainboard is a OEM manufactured by msi for NEC.
The support belongs to nec, and there is nothing to be found at the msi homepage.
Basicly its just to connect the 20 or 24 pin power connector, and the 4 pin atx power supply.
Next connect the power to the dvd and harddrive.
Then connect the data cable from the drives to the mainboard.
The front panel connector looks like this:
This is basicly the same for all msi mainboards.
Next you can power up the pc, and enter the bios and set the boot order ( press the delete button when posting )
Lay the windows disk in the dvd drive, and leave the bios and save your settings.
Now your ready to install windows.
The drivers can be downloaded here:
http://www.nec-computers.com/support2/pib.asp?platform=platform_callisto_g_mt&mode=2000&title=Downloads
Best of luck
Mar 18, 2013 | MSI : MS-7061-020...
I need to wire my sony cd player into my fiat cinquencento but I have no idea how to wire it in I just spent 23 on a wire for the stereo an it only cost me a tenner for the actual stereo I dont want to...
most car stereos are simple to wire, especially sony!
Main power cable colours are:..
RED = LIVE (+)
BLACK = NEGATIVE (-)
YELLOW = MEMORY/SWITCH LIVE it will be next to the red and black cables
ORANGE AND WHITE = ELECTRIC ARIAL (IF FITTED)
BLUE = REMOTE WIRE (FOR AMP CONTROL IF USING)
You should now be left with a couple of audio out jacks and speaker cables,
the speaker cables are straightforward, most have a twin, ...E.G if you have a grey wire, this should be next to a grey and white (or grey and black, depends on model) wich is classed as its PAIR/TWIN.............
an so forth,...green, purple, white, brown.....ect ect
each colour havin a twin as stated ealier!! (they are twinned, as the solid colour is usually the negative speaker, and the solid colour with a stripe through it is usually the posative speaker connection (eg..single solid colour is (-)...and...solid colour with stripe is posetive (+)...)
Apr 30, 2011 | Car Audio & Video
I NEED DRAWING FOR THE FRONT PANEL CONNECTION
Download the manual for you're MSI PM8M-V motherboard from MSI; http://www.msi.com/index.php?func=searchresult&keywords=PM8M-V&table=download
You will need to download and install Adobe reader to view the manual. Download Adobe; http://www.adobe.com/products/reader/
Open manual to page 9. See Front Panel Connectors: JFP1 & JFP2. There is no need to connect JFP2's Power LED jumper, this is completed at JFP1. Each wire jumper coming from the case will have one wire color in common with all connectors except the speaker jumper. That common colored wire will be use as negative.
The speaker wire commonly as red is positive and black is negative.
Cheers'
Mike
Apr 22, 2010 | MSI PM8M-V Motherboard
Msi motherboard for model k8t neo ms 6702
Its the model numbers that vary the most when looking for the manual. Click on the link below to open MSI download site;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+NEO&table=download
While on MSI's site I searched for MS-6702 and left out the term, "K8T NEO". MSI provided the another link; http://www.msi.com/index.php?func=searchresult&keywords=MS-6702&table=download
The model numbers K8T Neo-FSR and FIS2R, use the same manual.
See link; http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565
K8T Neo2-F and FIR use the same manual.
From the pic included, Connect everything to JFP1. Connect the speaker to JFP2.
b972b2a.jpg Wire colors do vary from case to case. Normally solid colors like red, green, blue and dark blue are used as positive. White and black are negative. Each jumper pair will share a common color. That common color is negative except when hooking up the speaker wire. Black is used for negative.
Cheers!
Mike
Oct 24, 2009 | Computers & Internet
Help with front panel cables connection, case to mainboard.
The best place to look would be msi.com. Click on the support link and lookup your specific board model #. All drivers, and manuals should be available there for free download. Hope this helps.
May 04, 2009 | Computers & Internet
Instalation instructions required
Uhmmm. . .okay. . .I would use nothing less than 16AWG speaker cable. Do not run the speaker cable parallel in close proximity to any AC wiring. Speaker cable rated to run through walls with usually be color coded red and black. Connected the red to the red on the speaker and red on your home theatre receiver. Do the same for the black. If speaker cable insulation is clear, look closely for subtle markings or writing on the insulation. The writing will only be on one of the two wires. Designate that as the POS or PLUS or + or RED. Connected it to the red on the speaker and the red on the back of your home theatre receiver. The other is by default the black and connect it to like colors. Repeat for all 5, or 7 speakers in your theatre. Your subwoofer probably has a seperate amplifier, so it gets it's power from it's own AC power plug. . .so plug it in. The sound coming from the Home Theatre receiver will be low-power and will carry on an RCA cable. Look for the subwoofer output on the home theatre and connect it to the input on the subwoofer. There may be a right and a left input on the woofer. . .it doesn't matter which you plug it into. . .either one will do.
Mar 09, 2009 | Audio Players & Recorders
What does red versus black equal?
from cd player to amp:
connect red from cd to red on the receiver's CD input( and white to white) using RCA cables:
http://en.wikipedia.org/wiki/RCA_connector
Red is usually right channel and white left channel.
From amp to speaker, use speaker cable and and make sure that you connect red to red and black to black. Notice the stripe on the speaker wire to help you do this. you could think red as 'positive' and black as 'negative', though they are not in the theoretical sense, as they carry ac signals.
Aug 14, 2008 | Polk Audio RTi100 Main / Stereo Speaker
Jul 23, 2008 | Intel Motherboard
MS-6378 ver 2 Motherboard fitted to my Time Computer
here it is your manual man
http://asia.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
msi site your board/the manual..youll have there at the beginning the diagram of wires and pins..
I have a MSI too..great boards man..great boards..
fixya:)
bye
Feb 07, 2008 | MSI MS-6378 Motherboard
Intel Motherboard Logo
218 people viewed this question
Top Intel Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
