Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Picture freezes for a couple of seconds and then catches up every few minutes.I'm hooked to cable
Posted by akitagandy on
Arnel
    Sergeant:
  • 184 Answers
If ok with DVD, tighten the coaxial cable from wall outlet to cable box and if still the same replace the box. :)
Posted on Dec 26, 2009
Acer aspire one beeps once then freezes for a couple seconds
Remove ram memory stick one at a time and test as you go making sure there is one stick in place at all times.
We get gaps in reception when watching on demand movies. Is this a problem with the TV or with the cable service? (the screen freezes for a few miliseconds and then "catches up" and contiues)
you have a receiver and dish right if yes so the screen in freezing because the dish needs adjustement to get the full needed signal. anyway when the picture is freezing you can check the signal it should be weak
2helpful
I have a samsung model hlr4667wx/xaa picture freezes
analog board can cause that symptom especially if the pic is freezing .
12helpful
3answers
Sony lcd tv picture freezes
I saw the solution posted to your problem talking about the picture freeze feature on Sony TVs. I presume you're not touching a button on the remote when your picture is doing this.
Normally when a picture freezes it isn't the TV but the signal the TV is receiving from whatever source it's hooked up to. If you have digital cable and the company is having any type of technical difficulties with their signal, it can cause the picture to freeze. If you've ever watched TV with someone who has Dish or DirecTV while a storm was over-head, you may have seen it happen to their picture. However, if you're able to rule out the cable equipment and the cable company as being the problem, then there is something wrong with your TV. If your TV has this picture freeze feature the other guy was talking about, it's possible the feature is now malfunctioning . Whatever the case, if it's the TV the only troubleshooting you can try is to unplug the unit for 30 minutes. If that doesn't fix the issue, the TV likely needs to be serviced. Follow the link below and it will take you to Sony's esupport page. There you will find a phone number you can call, or you can chat with someone online regarding your particular issue. Good Luck!
I hope I've provided you useful assistance and that this informationallows you to make an informed decision as to how to proceed fromhere. Please be sure to vote on my response. I hope I've earned agood rating from you today.
Please post a comment if you needadditional assistance so that I can help you further.
Picture will freeze.
Either the disc is scrathed or you have to remove the cover and take a q-tip with rubbing alcohol and clean the lens.
5helpful
DVD player picture freezes
hi u can purchase a sony DVD lense cleaner which can make ur dvd player lense perfect for running various kind of dvd... pls rate me
Samsung HLR6167 - picture freezes
This is very common in Samsung DLPs. The DMD board is going bad. You will need to replace it.
Frames freeze every few seconds
Sounds like a weak cable signal. Contact your cable service provider and ask to have a tech check your incoming line strength.
DVD player freezes
If it's a very cheap unit, it's possibly because the machine can't process the information quickly or efficiently enough, thusly causing the picture to freeze up while the processing catches up with it. Friend has a $30 unit, which happens to constantly.
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
