SOURCE: Error 43Our Bosch range will not open after setting to self clean Error Code:F43Cause: Upper (or single) oven motorized latch will not unlock; Defective or jammed upper oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis. 5. If F43 persists, replace power board
Bosch error F45
Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; defective latch motor or its wiring.
Check that neither latch switch nor common wires are pinched to the appliance chassis.
Do this and follow the common sense. God bless you Lower motorized latch will not lock; Defective or jammed lower oven door or latch switches; Defective latch motor or its wiring.
1.
2.
3.
4.
Check P10 connector and check if latch motor wire pinched to the appliance chassis.
Poor contact of the fuser drawer connector may cause the following
error codes: C41~C46, C4A, CD5, E01, E03. To correct this issue, a spacer (see SPL p25 item 1 attached) has been added between the fuser connector and the frame; also the springs (see SPL p24 item 8 attached) have been changed to provide more tension. This change has been applied since January 2003 production: e-Studio 550 TA314824 e-Studio 650 WA312627 e-Studio 810 XA311627 Model P-I Before Change After Change e-ST550 25-1 --- 6LA14365000 e-ST650 SPACER-DRW-CNCT e-ST810 24-8 6LA08946000 6LA14468000 SPC067-070-140 SPC068-080-160
Corrective Action:
1.
2.
3.
4.
5.
Here is the error code and things to check on your oven. Error Code:F41Cause:
Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; Defective latch motor or its wiring.
Corrective Action:
1.
2.
3.
4.
Check that the solder joints in header P24 on the power board are not broken.
5.
Regards
Alan Hood
ami-man
