Question about Just Wireless Bluetooth Headset Wireless Headset
Pair to a sony ericsson w760a to a just wireless bt-35k2 bluetooth wireless head set
Posted by bruce5456 on
Anonymous
    New Friend:
  • 5 Answers
Put your device in search mode.
Put the bt-35k2 headset in pairing mode.
(Press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode.)
Once device detects headset, you'll be prompted for passkey; enter 0000. Pairing will complete once authenticated.
Posted on Apr 24, 2010
I have the just wireless blue bt-35k2 headset and it stopped being recognized by my phone. When I tried to add it back I need a pass key and I can't find my manual.
To put the bt-35k2 headset in pairing mode, press the ON button but hold it down for about 6 seconds. Once detected, you'll be prompted for passkey; then use 0000. Pairing will complete once authenticated.
Mar 24, 2010 | Just Wireless Bluetooth Headset Wireless...
Can I pair my Wireless Blue BT-35K2 with my 3.0 iTouch?
Give this a try:
1. Put your device in search mode.
2. Put the bt-35k2 headset in pairing mode (press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode.)
3. Once device detects headset, you'll be prompted for passkey; enter 0000.
Nov 18, 2009 | Apple Premium Skin Case for iTouch 2nd...
Problems pairing my Just Wireless Blue BT-35K2
If you can get the headset into pairing mode, and your phone into detection mode and it's still not pairing, try removing the battery while powered on. Replace the battery and retry, and it should work.
Jun 26, 2009 | Cell Phones
Will not let me connect the blue tooth to my phone
ur just a ********..haha nah jk
i got the same problem. help...
Apr 24, 2009 | Just Wireless Bluetooth Headset Wireless...
Need PIN for Just wireless bluetooth
If you haven't reset the password, try 0000 or 1234. That is usually the defalt for most devices.
Mar 24, 2009 | Cell Phones
I can't place or recieve calls with my just wireless bluetooth BT-35K2
To put the bt-35k2 headset in pairing mode, press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode. Once device detects headset, you'll be prompted for passkey; enter 0000. Pairing will complete once authenticated.
Mar 24, 2009 | Just Wireless Bluetooth Headset Wireless...
Bluetooth
well make sure that your phones' bT is visible then have the phone search for your BT headset when it ask for the code enter 0000....now it should be paired and you are good to go and use you headset.
Jun 04, 2008 | Sony Ericsson K800i Cellular Phone
Pairing with my Sony Ericsson w810i's MP3 player
hi stefan,
sorry to let you know but sony w180 does not suort an A2DP profile,
which is necessary to listen music wirelessly. so u'll have to change ur handset if
u want to listen to music via ur bluetooth headset.!!
good luck!
Dec 11, 2007 | GN Netcom GN Jabra BT620s Bluetooth Stereo...
Pairing Problem
It may be that the phone does not play music through bluetooth and that it only plays through the earphones that come with the phone. The only way to find out is to read the documentation on the phone or try another bluetooth headset, really. The headset cannot be faulty as it pairs correctly and it works with calls. Bluetooth headsets are not really intended for playing music as it drastically reduces battery life.
Sep 07, 2007 | Sony Ericsson Universal Bluetooth...
Just Wireless Bluetooth Headset Wireless Headset Logo
186 people viewed this question
Top Just Wireless Radio Communications Experts
Anthony Ward
Anthony Ward
Don Eagan
Bill Boyd
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
