Nextar MA7151B MP3 Player Logo
Posted on Dec 26, 2009
Windows media player won't recognize my mp3 player. It says "searching for devices" and it never recognizes it. PLEASE HELP!
5 Related Answers
Anonymous
  • 38 Answers
  • Posted on Sep 13, 2008
SOURCE: NEXTAR MP3 Player 2GB
Bearshare only reconise mp3 products like (ipods,zens,etc),but the other way of putting songs on an mp3 player is:
1)click "start"
2)click "my computer"
3)click the device name (eg.my_sonywalkman)
4)drag and drop the songs you downloaded from bearshare.....
5)unplug your mp3 device
6)Enjoy the music!
(if windows doesnt recorgise it,please search and install the drivers @ http://driverzone.com/ )
Thanks for your question,have a nice day!
(IF ITS POSSIBLE,COULD YOU RATE THIS SOLUTION "SO I CAN HELP LOTS OF OTHERS WITH THERE PROBLEMS....)
Thanks again!
Anonymous
  • 9 Answers
  • Posted on Oct 04, 2008
SOURCE: MA166 MP3 Player not recognizing..Windows XP
See the last posted solution, and the model number is not what you quoted, but MA566.
Anonymous
  • 1019 Answers
  • Posted on Jan 05, 2009
SOURCE: computer doesn't recognized the mp3
this could be a vista compatability issue.
if you have driver or installation cds with the players, try installing any software.
also try a different usb port on the computer, as the port may have already assigned itself, for other devices.
try looking in the device manager, to see if the computer detects the device. but has problems or issues. usually a yellow triangle or exclamation mark.
Finally connect the device, and use ( Add new Hardware Wizard )
thankyou for using Fixya.
Mike @ compurepair.
Anonymous
  • Posted on Nov 16, 2009
SOURCE: when i plug my nextar mp3 player item # MA933A-1P
Just Drag and Drop your MP3 files onto the drive tht was created. Look in "My Computer" for "Removable Disk", double click on it,then copy your MP3 songs from your music folder (right click, copy) and paste them (right click, paste) into the MUSIC folder on the "Removable Disk"
Anonymous
  • Posted on Jan 22, 2010
SOURCE: Windows Vista doesn't recognize my MP3 player.
whats a control pannel?
It wont connect with my computer
Search Results
    My laptop does not recognize my mp3 player [Solved] - CCM
    ccm.net > Forum > Hardware > Laptop
    Jan 18, 2013 - Connect the player, open device manager, right-click on WALKMAN under .... my sony mp3 walkman,my computer dont recognize it,i cant upload my .....Does not charge. is not recognized by windows media or My Computer. My computer does not recognize my mp3 player.
    Nov 16, 2014
    I cant get my songs to my mp3 player
    Oct 11, 2013
    Sony Mp3 Walkman is not getting Detected !
    Oct 31, 2012
    More results from ccm.net
    My PC does not recognize my MP3 player - CCM
I purchased this sansa clip mp3 device two days ago and my computer just won't reconize it and respond. I noticed that yellow sign in the usb device list,tried doing everything possible, searched google...
Open your Windows Media Player then plug the sansa in ... it should recognize it .. sometimes it takes a few tries to get it to work .... I think the f5 key refreshes in windows media not for sure try it a few times to see if it finally recognizes it ... hope this helps
1helpful
2answers
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Windows media player wont recognize my mpe player
windows media player is not suppose and will not operate apples ipod.....go to www.apple.com and download itunes.....this will recognize your ipod and help you manage your songs....(once itunes is downloaded scan pc for music files).......you still can use window media player just not with ipod..you can either get tunes via itunes or (limewire, frostwire or bearshare)
I have a sansa clip mp3 player and I lost the disk???
It should be recognized by your computer. I did a search for drivers and they are not needed for this model.
For music, After the computer has recognized it has been plugged in. Start, My Computer, and it should show up in there as (my sansa or sansa clip) something along those lines.
You may open it and drag your music files into the accroding folders inside the device.
OR You may use Windows Media Player 11 to Sync to your Mp3 Player. The Sansa Clip has problems with Windows Media Player 10 so i would reccomend using Media Player 11 to sync.
For future help or more questions please comment,
I hope this has helped :)
Computer will not recognize mp3 player
Find the MP3 player in the device manager, delete it, then plug it in again and see if Windows recognizes it and reinstall the drivers properly.
If on the second try windows does not install the device drivers properly, find it in the device manager right click on it and click update drivers
Siren MP3 player not recognized by Windows Explorer‏‏
Installing the latest Windows Media Player solved the problem.
My computer doesn't reconize my mp3
check if your usb cord if defective.
To check if the mp3 is recognized by the computer go to device manager in the compuer properties.
Go to device manager go to hardware tab and search for new hardware, if you see a question mark in the usb port it means that the computer cant recognize it and you may need a driver. Some mp3 have cd installer of its software. Install it in your computer. and try if the computer can recognize it.
also check if your usb port is working properly...
Mp3/digital media player
maybe u need a windows media player upgrade...u need windows 10 of 11 for newer mp3s
2answers
Computer does not recognize Gigabeat Device
Check the manufacturers website for specific Vista drivers.
Top Nextar Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Vinho Xie
Vinho Xie
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
