Dell Ethernet Card Network Adapter Logo
Johnny Arellano Posted on Dec 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need instruction on ethernet adapter
Cannot install dsl needs ethernet adapter whats the correct one and how to install
Francisco Cortes
Level 3:
  • Master 781 Answers
  • Posted on Dec 25, 2009
Francisco Cortes
Master
Level 3:
Answers
781
Questions
Helped
260184
Points
2122
First:
there's no specific network card you should get, although you probably may want to make sure you get one that support fast ethernet and gigabit ethernet. make sure also is pci card (most of them are), the other part depends on your budget, netgear, linksys, dlinks are all great brands but the one you pick doesn't have to be.
check some options here
second:
this is how to install a nic card (network adapter / network card)
Installing Network Card
  • First step is to read the users guide and familiarize yourself with the new card.
  • Power down PC and remove the AC power cord.
  • Open the computer case.
  • Find an available Peripheral Component Interconnect (PCI) slot on the motherboard and remove slot insert if one exists.
  • Carefully remove the network card from its static-proof plastic envelope, and slide it into the slot.
    • Seat the card in the slot firmly with gentle pressure along the length of the card, especially right about the slot itself.
    • Snugly, screw the card to the computer frame, but do not over tighten.
  • Close the computer case.
  • Plug your computer in and power it up.
2Follow this procedure to verify Windows XP recognizes the new card.
  • Click Start, then click Control Panel.
  • In Category View (vs. Classic View) click Performance and Maintenance.
  • Click "System" icon at bottom of window.
  • Click the Hardware tab.
  • Click the Device Manager button.
  • Double-click Network Adapters.
    • Beneath it should appear the name of your Ethernet card.
  • Next, double click the name of your Ethernet adapter.
    • If the text in the "Device Status" box says "This device is working properly.", then you successfully installed the card and are finished.
    • If the text in the "Device status" box doesn't say "This device is working properly.", then write down on a piece of paper what it says and continue with next step.
We bought the AT&T Motorola DSL Modem today, and we're trying to connect to wireless on a laptop and the connection isn't showing up. How do we fix this ?
  1. Ensure that your AT&T DSL self-installation kit is complete. At minimum, it should contain a DSL modem, an AC adapter, an Ethernet cable, a telephone cable, several telephone filters and an installation CD.
  2. Install the telephone filters on each telephone jack that you have a phone plugged into. Install a dual phone adapter on the jack closest to your computer if you have an answering or fax machine, telephone or analog modem in the same room. Then plug your telephone equipment into the filters. Connect the telephone cable that was provided with your installation kit into an unfiltered telephone jack.
  3. Insert the installation CD into your CD-ROM drive. If the installation program does not start automatically, click Start > Run > and browse to the CD-ROM drive directory to find the installation file.
  4. Connect the telephone cable that is attached to the unfiltered wall jack to the back of the DSL modem. Connect the Ethernet cable to the back of the modem and to the Ethernet network interface card port on the back of your computer. Connect the AC adapter to the back of the modem and plug it into an electrical outlet. Power the modem on.
  5. Check the modem lights. There should be at least two lights lit. These will have labels such as "Power" and "Ethernet." However, these labels may differ depending on the model of modem you received in your installation kit.
  6. Complete the software installation. Enter your chosen username and password when prompted. Check your modem to see if the light labeled "DSL" or "Internet" is lit. Open a web browser window to see if your DSL service has been successfully installed.
2answers
Just connected router to clear network modem and VoIP (wireless phone service), now when the phone ring, it disconnects me from the internet and the connection is lost until the phone call is complete.
Is your modem a DSL or cable modem?
If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
The DSL modem does not need a DSL filter on the phone line.
1helpful
I lost my dlink d1514 installation cd, have dsl set up
You can download the driver for your adapter from D-Link's support page here.
There are 5 different versions, so make sure you get the correct one.
You can then either burn that file on a CD or copy it on a USB stick - it is too big for a floppy though - and install it on your downstairs computer.
Of course you can carry the computer upstairs and connect it to the router via an Ethernet cable, but that would be my last resort.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
1helpful
3answers
How to connect DSL internet to the second computer
You need an ethernet card, either hard wired or wireless to connect your computer to the DI-624.
2answers
There is only a phone port and the types of cord thats connected to my dsl are different what type of cord do i need is there a universal one
the one that connects to your dsl should be Ethernet. Are you sure there is no network port on your PC? the image below shows where this port is. does the dsl fit in here? cf5ca22.jpg
Need Ethernet port on PC
If you have a wireless router then the ethernet cable will go between the modem and the router. Then you need a wireless LAN card to connect the PC to the router
What model router and modem do you have?
PC wireless card
Lan
Okay so if I understand your question....your desktop has DSL and you want to connect your laptop to the same DSL connection? If that is the case then what you need is a router. A router will share the DSL connection between the desktop and the laptop. A wireless router will allow your laptop to surf wirelessly if it has a wireless adapter or you can plug it into the ethernet port on the laptop. You can purchase one here. The instructions are pretty simple and straightforward and should be included with the router.
2answers
Ethernet for my dell 4600 pc
No, you don't need a card, as long as you have an Ethernet to USB adapter, you should be just fine.
2answers
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
1helpful
3answers
Hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
