You can connect Nokia 2690 using bluetooth and using Nokia connectivity Cable CA-101 which will fit to the USB port of your laptop.
(NOKIA connectivity cable)
Procedure on how to connect:
1. Bluetooth (This will work with the laptop with bluetooth)
First, remember to turn on the Bluetooth feature and make it
discoverable by other devices (My Phone's visibility -> Shown to all)
on cell phone, so that it can be detected by laptop.
Then, click on the
add devices in the
control panel of your computer. Click start> control panel
2. Add Bluetooth Device Wizard window will appear, tick
My devices is set up and ready to be found and click
Next.
3. The wizard will then search the Bluetooth devices nearby, and will show
the found devices. Here the wizard found my cell phone named David.
Click the device you want to add, after that click
Next.
4. Ok. Here the wizard will ask whether you need a passkey to add your
device, so that the communication data between laptop and cell phone
will be encrypted later, here I would recommend you to either select
Choose a passkey for me or
Let me choose my own key. In this example, I select choose a passkey for me.
The wizard will then show the passkey and you need to key in to your
cell phone. After that, the laptop will try to install the Bluetooth
device. If you have Bluetooth program for your cell phone, you can
install it as Windows Vista might have problem to install the device .
For my case, I install Nokia PC Suite on the laptop, so I can transfer
wallpapers and videos later.
Note: Also your cell phone will get the prompt to accept connection from laptop, and you need to click yes.
5. At last, click
Finish to complete the Add Bluetooth Device Wizard.
6. And now, you will see the new bluetooth device added which is your Nokia 2690 phone.
Here's another way on how to connect your cellphone to your laptop.2.
Hard Connection using Nokia connectivity Cable CA-101
You can get this from any nokia stores.
Procedure:
Just connect the other end of the wire to your cellphone and the other end to the usb port in your laptop. Follow the onscreen instructions in your cellphone.
Check your laptop if your cellphone has been detected, once it's connected you can then access your pictures or other files in your cellphone. You can even transfer files.
I hope this helps.
Please rate this solution. Don't forget to leave your comments/suggestions on how I can improve my service.
Thanks..
