Question about Yes PDV-102CRT Portable DVD Player
Turn off elapsed time in Yes PDV-102CRT - Yes PDV-102CRT Portable DVD Player
Anonymous
    New Friend:
This unit comes with a remote control Use the remote to change the screen option and hide the elapsed time.
Posted on Dec 26, 2009
Konica minolta buzhub c360 giving error c1183
Elevate drive malfunction
<When FS-527 is installed> • During downward movement, the tray 2 upper limit sensor (PS24) is turned OFF and the tray 2 lower limit sensor (PS21) is turned ON. • The elevate motor (M15) lock signal remains set to H for a set period of time while the elevate motor (M15) is turning. • The tray2 upper position switch (SW2) is turned ON even after the set period of time has elapsed while the elevate motor (M15) is energized. • The tray2 lower position switch (SW3) is turned ON even after the set period of time has elapsed while the elevate motor (M15) is energized. <When FS-529 is installed> • When the exit tray is moving up: When the tray up/down motor (M2) starts rotating with the output of the tray lower limit sensor (PS6) being ON, PS6 is not turned OFF even after the set period of time has elapsed. • The paper surface detect sensor/1 (PS2) or the paper surface detect sensor/2 (PS3) is not turned ON even after the set period of time has elapsed after the tray up/down motor (M2) starts rotating. • When the exit tray is moving down: The tray lower limit sensor (PS6) is not turned ON even after the set period of time has elapsed after the tray up/down motor (M2) starts rotating. Remedy When FS-527 is installed: 1 Check the connector between M15-FSCB PJ4 for proper connection and correct as necessary. 2 Check the connector between PS21-FSCB PJ21 for proper connection and correct as necessary. 3 Check the connector between PS24-FSCB PJ16 for proper connection and correct as necessary. 4 Check the connector between SW2-FSCB PJ3 for proper connection and correct as necessary. 5 Check the connector between SW3-FSCB PJ3 for proper connection and correct as necessary. 6 Check the connector of M15 for proper drive coupling, and correct as necessary. 7 PS21 I/O check, sensor check. 8 PS24 I/O check, sensor check. 9 SW2 I/O check, sensor check. 10 SW3 I/O check, sensor check. 11 M15 operation check. 12 Change M15. 13 Change FSCB.
When FS-529 is installed: 1 Check the connector between M2-FSCB CN12 for proper connection and correct as necessary. 2 Check the connector between PS6-FSCB CN5 for proper connection and correct as necessary. 3 Check the connector between PS2-FSCB CN4 for proper connection and correct as necessary. 4 Check the connector between PS3-FSCB CN4 for proper connection and correct as necessary. 5 Check the connector of M2 for proper drive coupling, and correct as necessary. 6 PS6 I/O check, sensor check. 7 PS2 I/O check, sensor check. 8 PS3 I/O check, sensor check. 9 M2 operation check. 10 Change M2. 11 Change FSCB.
Apr 12, 2016 | Konica Minolta Office Equipment & Supplies
The battery was disconected and now when i turn on the radio it says wait 1 hr
Yes on some vehicles you have to leave the ignition on. If you turn off beforehand you must wait all over again. Will ask you for a code normally after this time has elapsed.
Good luck with it.
Apr 01, 2011 | Car Audio & Video
No image and sound is normal, is correct TV system, but, weak image in the light of the sun, inside house is no image
go to your color in settings on remote and turn the brightness up a notch not to much just a notch.
Feb 05, 2011 | Yes PDV-102CRT Portable DVD Player
White screen not reading disc including CDs, DVDs. It appears that the lens/motor is not running. plain white screen is displayed. what could be the problem.
Usually suspect condensation problem, let it dry out and try cd first.White screen maybe contact resistance in the connector due to condensation from room humidity.
Dec 01, 2010 | Yes PDV-102CRT Portable DVD Player
Subaru legacy 2006 E/T shows up were it tell you how many miles a gallon you get
Yes that's elapsed time from when you turned on the ignition. Press the black button underneath the display to change mode to outside temp or mpg or miles to empty......We've got the 05 Legacy 2.5i with the same function/display......
Oct 02, 2009 | 2006 Subaru Legacy
Bizhub 350 erro code c1183
C1183
Elevator motor ascent/
descent drive failure
• The elevator tray lower limit sensor (PC13) is not turned ON
even after the set period of time has elapsed after the main
power switch is set to ON.
• The elevator tray home position sensor (PC11) and elevator
top face detection sensor (PC12) are not turned ON even
after the set period of time has elapsed after the elevator
motor (M11) is energized.
• The elevator tray does not stop at the position for the specified
tray after the elevator motor (M11) is energized (beginning of
descent operation) and the elevator tray lower limit sensor
(PC13) is turned ON.
• The elevator top face detection sensor (PC12) is not turned
ON even after the set period of time has elapsed after the elevator
motor (M11) is energized (beginning of ascent operation)
when paper is being fed out.
May 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Type mismatch in MSFlexGrid Control
type mismatch error occours when there is a mismatch between the value which you are trying to assign to a variable which is dimensioned to store values of another, first you check if the datatypes match each other by applying the break.
Dec 19, 2008 | Microsoft Visual Basic 6.0 for PC
Durabrand pdv-709
Turn Player On
Open Disk Tray (Leave Open)
Using the Remote Control Press 3 5 9 7 3 5
Select 0 (Zero) For Region Free (MULTIREGION) or 1 ~ 6 For Region Specific if Required
Dec 03, 2008 | Durabrand PDV-709
Yes PDV-102CRT Portable DVD Player Logo
135 people viewed this question
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
