Canon Rebel XT / EOS 350D Digital Camera Logo
Question about Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt 1. image looks blury in eye
Canon rebel xt
1. image looks blurry in eye piece but pictures come out correct.
2. flash is up and you press playback button flash will go off
Posted by montiel18 on
Anonymous
    Scholar:
  • 54 Answers
1. The viewfinder's diopter is probably out of focus (doesn't affect Auto Focus of photos). There's a dial and a +/- symbol next to the viewfinder. Turn the dial till you can see clearly through it. Alternative reason: The glass in the viewfinder is dirty/foggy. Use camera cleaning solution (a drop) on a cotton bud to clean it.
2. Malfunction needs Canon Service Centre to take a look at.
Posted on Apr 16, 2010
Whyb when i use the flash off mode are my pictures blurry
The flash duration is so short that it literally "freezes" all movement. With the flash off, any movement from you while clicking the shutter button will show up as blur in the pictures. If you can't hold the camera steady, consider buying a monopod or even a tripod. Or better yet, get a camera with built-in image stabilization.
Taking pictures without using the eye piece.
The XS does not have the feature of using the display screen for composition/preview of images like the smaller compact digital cameras. You will have to use the eyepiece like a standard SLR.
1helpful
Veiw finder(eye piece ) out of focus pictures are fine
Use the diopter adjustment to refocus the viewfinder to your eye.
Point the camera at a sign or something with writing on and half press the shutter button to focus then move the little adjuster at the top right of the viewfinder until the image in the veiwfinder is in focus
Blurry
Hey abbyr,
The most common cause of blurry images is called camera shake which is the slight movement of the camera caused by hand holding the camera during exposure. This cause can be solved by setting the camera to shutter priority and shooting with a faster shutter speed (1/60th of a second or faster). If you are using flash this is most likely not the problem since the shutter speed with flash is irrelevant since the duration of the flash determines the exposure. Another cause of blurry pictures is caused by not prefocusing on your subject prior to taking the image by holding the shutter button half way down so the camera can achieve proper focus before taking the picture. If none of this helps I would bring your camera to a local camera store and have an expert look at it and make sure you have it set up properly, and if you do I would have it looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
1helpful
Can't tell when Rebel xt is focused
So the problem is that it always looks blurry?
If so, look at the little dial that is coming out of the viewfinder. It corrects the viewfinder for people with bad eyesight, kind of like built in glasses. make sure the white marks are lined up.
8helpful
Rebel XT pictures are in focus but look blurry in viewfinder
Use the little wheel dial with the +/- sign on it right on the viewfinder...ajust it until things are clear
LCD Monitor
no
when looking through the eye piece, press the shutter button half way down, you will see red focus points. Use those to align the image.
1helpful
Blurred football pictures
low light means the shutter stays open longer to capture the image.   Try changing exposure settings.
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
