Question about JVC S-VHS Tapes (ST120SVDU2) S-VHS Tape
How do i go about transfering vhs-c video from an
How do i go about transfering a vhs-c video filmed in an old jvc camcorder to a armada e500 laptop any advice would be great thanks
Posted by helencrossla on
Sam
  • JVC Master
  • 3,247 Answers
You have several options. But important one to understand is the limitations of a PIII computer like Armada e500. You may not have enough grunt to convert stuff, even after buying the necessary video capture devices which work on USB.
Also I am assuming you either have the jvc camcorder still available or atleast have a VHS-C to VHS adapter to play the tapes on a standard VHS tape player.
Unless you are having a lot tapes and need editing while converting, your better bet might be to go to one of the shops that convert these tapes on to DVD or a suitable flash drive which might work out cheaper and quicker.
The last time I did this thing (quality of my VHS-C tapes was bad) I bought a Samsung combined VHS Video / DVD recorder and used the dubbing feature to burn DVDs. Cost me about $150 a year ago. I was able to do some editing on the way as I was connected to the TV screen as well. Saved me the hassles of dealling with the PC type video capture devices and software.
Posted on Dec 25, 2009
How do i connect crw-785 to compaq armada e500
This e500 has USB1.0 and transfer rate will be slow. If you use Win 98 then install the USB driver (get on web) first. Install software then plug in the USB lead from the crw-785 and don't forget to plug in the DC adaptor for the drive, (e500 USB port does not have enough power to run external drives other than some older thumbdrives).
Feb 24, 2015 | Compaq Armada E500 Notebook
HI There I have an old camcorder the Model is a JVC GR-DVL 150E i have some very old footage on the camcorder tapes, i never ever got around to transfering the footage on to vhs video tapes! but now i...
You need to buy USB 2.0 Video Capture Adapter Card to do this action..
Pls visit the URL below as an example..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
EasyCap USB 2.0 Video Capture Adapter Card TV VHS DVD Capture high quality audio and video through your PC's USB port. Capture playback from VHS, Camcorders, TV, etc; capture audio without a sound card! Supports NTSC, PAL, Video format. NTSC: 720 x 480 @ 30 fps PAL: 720 x 576 @ 25 fps.
http://cgi.ebay.com/EasyCap-USB-2-0-Video-Capture-Adapter-Card-TV-VHS-DVD-/360339776240?pt=LH_DefaultDomain_0&hash=item53e5eca2f0
Jun 27, 2011 | Cameras
Hi There! I have an old camcorder, model is a JVC GR-DVL150E . I would like to know if its possible to transfer my footage from the tapes on to my PC and save it to discs! if so how do i do this and what...
Thanks
Jun 26, 2011 | JVC Video Cameras
Conversion vhs to dvd
I can only offer you 1 option for this case.
In converting the VHS video tape to DVD you can use computer. All you need to have is the VHS player with RCA audio video cables. Then a computer that has video capture card or USB capture card. This will take time but you can just transfer all the copyrighted videos to DVD and to computer data (post to internet)
*Needs realtime transfer VHS to Computer with the prefered resolution option.
*Burn to DVD, it will depends on your DVD drive speed.
Mar 26, 2010 | Video Cameras
How to hook up jvc gr-amx18u vhs-c analog camcorder
I use a Dazzle transfer box via it's UBS port. I think I payed $85 bucks for it. BestBuy.
Mar 23, 2009 | JVC GR-AXM17U Camcorder
I have a JVC DR MV7SU DVD/Video recorder. How do
If your camcorder allows you to connect to a tv or vcr and allows you to record from it to the camcorder via the rca video input, then you should be able to record it that.  The camcorder must have the RCA audio/video inputs on it to be successful.
enov8
Mar 08, 2009 | JVC Televison & Video
Footage transfer
here....http://cgi.ebay.co.uk/AV-USB-VHS-TV-to-DVD-Capture-Card-S-Video-Grabber-Y35_W0QQitemZ120367919357QQcmdZViewItemQQptZUK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW?hash=item120367919357&_trksid=p3286.c0.m14&_trkparms=72%3A1300|66%3A2|65%3A12|39%3A2|240%3A1318
that one is in hong kong, but that is what I used time an time again. Just install the software, plug in the device, connect the red yellow an white leads to the red yellow an white leads that plug into the camcorder somewhere an off you go
Jan 18, 2009 | Sony Handycam CCD-TRV68 Camcorder
I need to transfer video to dvd
A good program to use that's simple and quick is Ashampoo Burning Studio 8. Also ConvertXtoDVD by VSO
Jan 03, 2009 | JVC GR-AXM310 VHS-C Analog Camcorder
Want to use jvc camcorder as webcam
I have just solved this problem for video - not checked audio as using it for stop frame animation. Just bought a USB Video adapter - Easycap and used the JVC Everio DV mini jack to red white and yellow phono into usb via adapter, install software and off you go. I bought a really cheap one to check-Under £10 new on ebay, also S video compatible. Perhaps a more expensive adapter may give better quality image, can also now transfer old VHS from videoplayer to PC-
Also possible to buy an internal capture card.to slot into your motherboard if you are up for that.
Scotty
Sep 02, 2008 | JVC Everio G Camcorder
How to download to pc
There's a device called a video grabber that will allow you to download your stuff on your PC.
Jun 17, 2008 | JVC COMPACT VHS-C CAMCORDER
Electronics - Others Logo
198 people viewed this question
Top JVC Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you a JVC Electronics - Other Expert? Answer questions, earn points and help others
