Samsung SyncMaster 931BF LCD Monitor Logo
Anonymous Posted on Dec 25, 2009
Vertical and horizontal not displaying property and shadows in picture.and do not know how to work the adjustment
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 25, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
176
Points
I fixed the adjustmen.ts by trial and error of monkeying around on monitor adjustments(no manual to work with).In the morning the shadowing was gone..think it is from over heated graphics cards.
My screen seems to be slightly out of focus - is there an adjustment I can make?
usually there is auto adjustment on the bottom part of your monitor. if there is none manually adjust it using vertical and horizontal adjustment tool in the same set of controls at the bottom of your monitor
1helpful
2answers
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • 0helpful
    Philips tv 20pt1782 want service manual
    hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me..
    Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
    There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
    Vertical rolling of picture
    psess the volume  up and down button together on the front pannel of the tv and then shut off the tv and it will stop scrolling.
    2helpful
    Viewing mode will only go from zoom to wide!!!! please help
    Hi!
    Found some relevant info on how to adjust your video settings... You might want to give it a try!
    Thanks! =)
    4.12 PC Input Picture Adjustment
    The Picture Adjust menu operates in the same
    way for the PC Input as for the DTV / TV input in
    section 4.2 for Backlight, Contrast, Brightness and
    Color Temperature.
    4.12.1 Auto Adjust
    When the MENU button is pressed, the On Screen
    Display (OSD) appears on the PICTURE ADJUST
    page. Press the button to highlight the Auto
    Adjust selection.
    Press the button for the LCD HDTV to adjust to
    the PC signal timing automatically.
    4.12.2 H-SIZE
    Press the button to highlight the H-Size selection.
    Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
    the horizontal size.
    4.12.3 Horizontal Shift
    Press the button to highlight the Horizontal Shift selection.
    Press the button to start adjusting the horizontal position of the picture. Use the or button to
    adjust the horizontal position.
    4.12.4 Vertical Shift
    Press the button to highlight the Vertical Shift selection.
    Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
    the vertical position.
    4.12.5 Fine Tune
    Press the button to highlight the Fine Tune selection.
    Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
    4.14.1 Understanding Viewing Features
    Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
    You can switch viewing modes using the remote control.
    4.14.2 Viewing Modes
    Normal Mode
    The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
    added to the left and right of the display image. Standard TV broadcasts are
    displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
    to as pan-and-scan or full frame. These movies were originally filmed in 16:9
    (widescreen), and then modified to fit a traditional TV screen (4:3).
    Wide Mode
    When watching a standard broadcast or full-frame movie in this mode,
    the display image is stretched proportionately to fill the TV screen.
    When watching a widescreen (1.78:1 source) program or movie, the
    display image fills the TV screen. If you are watching a widescreen
    (1.85:1 or 2.35:1 source) program or movie, there will still be black
    bars at the top and bottom.
    Zoom Mode
    When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
    program or movie, the display image is zoomed proportionally to fill the
    width of the screen. The top and bottom are cut off to remove most of
    the source material’s black bars. This mode is good for programs or
    movies with sub-titles.
    Panoramic Mode
    When watching a standard broadcast or full frame movie in this mode,
    the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
    horizontally on the left and right sides to fill the TV screen. The center
    of the image is not stretched.
    Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
    mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
    will return to widescreen.
    Convergence Adjust
    It means probably one of the two convergence ICs has blown
    3answers
    Horizontal display
    Check with the manufacturer information that you have the refresh rates and maximum resolution set correctly. If in doubt, go to your display properties and try something basic to test if this is the problem. A basic setting may be as low as 1024x768 at 60 Hz.
    (You can access your display settings by right-click the desktop anywhere and choose properties, then settings).
    Leave the monitor at that setting for a while to see if the monitor changes the picture.
    If the picture changes, it may be component failure in the monitor. If not, the problem is then related to the settings from your VGA card are too high or dense causing the monitor to fail after a time. Try something higher like 1280x1024 @ 60Hz and keep going till the picture fails. Compare the best functioning resolution with the manufacturer claims about the product in the product documentation.
    Be sure there are no cable bunches and the power cables are not wrapped up with the VGA cable under the desk or there are not too many cables lying about, although unlikely, this has been known to distort the picture.
    Let us know if this helps.
    Cheers
    Gund
    Colors not matched
    Yes,there are convergence alignment adjustments, to be adjusted
    by a technician after set is repaired.Replace STK392-560 IC's,then
    check alignment..........T.
    Top Samsung Computers & Internet Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Jean Thiebaux
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
