Question about Sony RECEIVER
No sound i bought a wii for xmas, i have a phillips tv and a sony receiver, the picture displays but no sound. please help
Posted by monika_marie on
Aldrine Manalo
    President:
  • 995 Answers
Kindly check all your connections and make sure that you are properly set it up. Make sure also that your sound volume of your tv is not set to mute.
Posted on Dec 25, 2009
How do you connect wii to a sony surround sound receiver
The best solution would be to see if your TV has and aux out for sound. It might also be called audio out. I would look like a red and white jack next to each other by themselves. Then you would take and audio cable and connect the audio out from your TV to the AUX in on the back of your Sony unit. Then select the AUX input selection on your Sony unit to hear the sound.
If you don't have an audio out on your TV then you can plug the red and white cables that go from your Wii console into the AUX input on your Sony unit. The only down side to this is you will ONLY have surround sound and no sound on your TV. Also you will have to pull your Wii cord apart a little bit to reach wherever you will need to plug them.
Please thank me if this helped.
Jan 29, 2011 | Nintendo Wii Console
Connecting Wii to HDTV - have picture, no sound
You also need to hook up the white and red rcas besides the green red and blue.
Feb 08, 2018 | Nintendo Video Game Consoles & Games
Just bought my wii set it up did my wiime then
please call 410-668-2342 and i will help u please call now, as i stop receiving calls after 4:00
Jan 28, 2010 | Nintendo Wii Console
I can't get my Playstation 2 or Wii to work with Vizio tv
I bought a RF Switcher Phillips SWS2325W/17 ...with this I was able to hook up my Wii...TV...DVD...and Directv...works fine...hope this helps
Dec 23, 2009 | Vizio Televison & Video
Bought a Wii and using the standard cables it played great on a new 50' Panasonic Plasma as well as on our 2 year old 32' VIZIO LCD. Just upgraded to a 46' Sony LCD (W series) and the Wii looks terrible...
The Wii can display on a HDTV, but keep in mind the output is only 480p. It is not true high definition, and it will only display this using a component video cable. There shouldn't be a difference with LCD and plasma.
You will also need to go to the display settings to force the Wii to display in 480p.
Try a different input (safe to assume your Sony has multiple?) and see if it is that specific input. Also, try a different device like a DVD player or VCR and see if you get the same result.
Good luck.
Dec 07, 2009 | Nintendo Wii Console
Wii to RX-V363?
Hi..
If youre talking about the set of 3 A/V plugs in the front then you need to connect to the Video Out (yellow) plug in the back that says something like "Front Video" or "video 3" out. Connect that to the display.
Jan 14, 2009 | Yamaha RX-V363 Receiver
Phillips 32" tv stuck in standby mode
thesupply is not responding
take your tv for repair
let them check power supply
semi conductors, transistors, zener diodes, an dfuse resistors, also check the switch contact,
and fuse,
Dec 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Can't get picture after connecting to receiver nad speakers
Sounds like something got confused in the re-wiring...if the TV signal from cable doesn't involve a box, then the co-ax should go straight to the "cable in" or "RF in" on the TV, and the sound equipment gets connected to output ports on the TV. Otherwise, try bypassing the video connections on receiver or whatever and go directly to TV...My surround sound has video in and out, but I've never used them, it doesn't matter.
Feb 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My t.v has sound but no picture
i have sony 24"tv they have no picture but having sound.what do you think this problem
Jan 11, 2008 | Sony KV-36XBR450 36" TV
Sound
Hi, your wii should provide sound through the Tv as well as the wii remotes, All you need connected should be the skart cable connected to the tv to provide the picture & sound.
i would suggest you contact the company you purchased the wii, due to its still under warrenty. i currently have 2 with no problems and didnt need to change any settings
have a good new year
john
Dec 31, 2007 | Nintendo Wii Console
Computers & Internet Logo
Top Sony Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
