Question about Panasonic PV-GS35 Mini DV Digital Camcorder
Panasonic PV-GS35 displays blue horizontal lines on playback;why?
Just bought a used Panasonic PV-GS35 and it seemed to work fine when I first tried it, but now all tapes played through it are seen as 1/2 covered by blue horizontal stripes. Help!
Posted by studio_mars on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: PV GS 35 wont play tapes from other cameras
perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
Posted on Nov 13, 2007
Anonymous
  • 5 Answers
SOURCE: Playback problem on Panasonic NV-GS15
It is probably a dirty head. One camera i had i had to clean it much more often that i wanted to and certainly before any important shoot.
Here is a tip though. Always use the same make of tape (and code). If you do change your tape (or code) then clean the heads before you put in the different tape. this is all to do with "dry or wet" lubrication used on different tapes. i do not know enough about that to comment, but the tip comes form a very good source.
Some people run the whole tape through on record (with the lens hood on) before they use it. I do not think it will help for this problem, but you can try.
Posted on Jan 01, 2008
johnychel
isaac johny
  • 796 Answers
SOURCE: Panasonic pv-dv
your picture LCD alone is bad or the even the output file is bad?
Posted on Mar 14, 2008
Anonymous
SOURCE: Can I have a driver for panasonic pv gs35 driver vista?
You don't need a driver. Just connect the camera using the cable provided with it; turn the camera on and set it to play movies. The first time it will upload the necessary drivers. THen, use Windows movie maker (it's included in vista, my version at least) to import the movie (if you don't find it, click on the start button and type "movie" on the search box). It's much better than the crappy software provided by panasonic anyways.
Posted on May 31, 2008
mydixie
  • 42 Answers
SOURCE: my screen is striped blue during playback
Your tape has a small latch on it that closes to protect from recording or eraser and opens to allow for playing or dubbing. Slide it open and see what happens.
Posted on Aug 12, 2010
During playback there are 5 horizontal blue lines that display. Can I fix this myself?
try with head cleaning cassette 2 or 3 times if problem presists change video head assembly
VEG1731
May 20, 2010 | Panasonic PV-GS150 Mini DV Digital...
Blue lines appear across screen during video playback.
thank you for choosing Fixya.com.
it seems that some parts in your Cam are Dirty.
please try to use the head cleaner disk first.
let me know if any changes happen.
goodluck
please don't forget to rate our answers properly.
Mar 03, 2009 | Panasonic Palmcorder PV-GS12 Mini DV...
Panasonic GS35
i suggest you insert a head cleaning casette to see if this removes the lines.the lines occur when one of the heads is dirty or not operating. if this does not solve the fault then the head might need changing.
Jun 16, 2008 | Panasonic PV-GS35 Mini DV Digital...
Blue Horizontal Lines
if you dont have time to get it fixed, tap on the side where the tape goes in. I had to tap it a couple of times before everything started work fine again.
May 06, 2008 | Panasonic Palmcorder PV-GS15 Mini DV...
Panasonic PV-GS35 Viewfinder screen connection problem in hinge joint
the hinge is definetly damaged and is going to need replacing. these hinges do need replacing if used allot because this is a moving mechanical part. This is not a easy thing to do, it needs to be done by a panasonic technician.
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
No image in viewfinder
CCD sensor faulty and has to be replaced ( you can playback fine but no image in capture mode ). Manufacturer's agent should repair this fault free of charge as you clerly bought a faulty product.
Aug 28, 2007 | Panasonic PV-GS35 Mini DV Digital...
Aug 18, 2007 | Panasonic PV-GS35 Mini DV Digital...
Panasonic PV-GS35 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
