Question about Epson Stylus Pro 9800 InkJet Printer
Service Request 00010005 - Epson Stylus Pro 9800 InkJet Printer
Posted by rmoser139 on
Anonymous
    Sniper:
  • 102 Answers
1. The CR Encoder and the T Fence must be free from dust and dirt or any other foreign matters.
2. The CR Timing Belt must be free from any defects and the belt must be in proper tension.
3. The carriage must slide smoothly, free from undue load.
4. Measure the resistance value of the CR Motor. (5.8Ω)
5. Execute encoder checking by “Encoder ”) in the selfdiagnostics menu.
6. All the harness must be connected properly and free from short circuit or broken wire.
7. Check the carriage home position sensor.
Posted on Jan 03, 2010
What does "service req. - 00010005" on epson 4880 printer mean?
http://largeformatrepairs.co.uk/errors/epson/sp4880/00010005/
Quoting from the link above:
Service Call Error 00010005 CR Motor Out Of Step During CR Motor operation, there may be a case where the encoder pulse signal within the specified range is not input within a specified period of time or the pulse width is extremely long or short. In such a case, the CR Motor is judged to be out-of-step, so that this message is displayed and the printer stops operating.
This error occurs on the Epson Stylus Pro 4880 large format printer and is not a routine maintenance request.
May 02, 2018 | Epson Office Equipment & Supplies
Message is Service call error 00010014 I have an Epson Stylus pro 9800 and I am getting a message saying: Service call error 00010004 error 00010004 SERVICE CALL 00010004DescriptionFailure of ...
Epson Stylus Pro 4400/4800/4880 Error Codes
Maintenance Request Codes:
• 0002 - CR Motor near end of life - Replace carriage return motor ASAP
• 0006 - Battery shut off - Replace RTC back-up battery
• 0040 - Cleaning unit near end of life - Replace cleaning unit ASAP
• 0080 - Date not set - Set the date through the printer control panel
• 0088 - RTC backup battery not installed - Install RTCbackup battery
• 0100 - RTC backup battery pressure is temporally low - wait for a while
• 0200 - The number of ASF paper feeding has reached predetermined value
• Service Call Codes
• 00000101 - CR Motor reached end of life - Replace carriage return motor
• 00010000 - PF encoder check error
• 00010001 - PF motor is out of step
• 00010002 - PF motor overcurrent has occured - Replace PF motor
• 00010003 - PF motor out of postion time-out error
00010004 - CR encoder check error - ensure enoder strip is clean & dust free
• 00010005 - CR motor out of step - click here for more info
• 00010006 - CR motor over current
• 00010007 - CR motor out of position time-out error - Replace the board assembley, main
• 00010008 - Servo interupt watchdog time-out error - Replace the board assembley, main
• 0001000A - Carriage home position detection error
• 0001000C - PG home position detection error
• 0001000F - CR motor PWM output faulty
• 00010010 - PF motor PWM output faulty
• 00010012 - CR overload (high sensitivity) error
• 00010013 - PF overload (high sensitivity) error
• 0001001B - Head Driver (TG) temperature error
• 0001001D - CR servo parameter error
• 0001001E - PF servo parameter error
• 00010020 - CSIC reading/writing error
• 00010022 - Ink type error (setting on printer body side)
• 00010023 - RTC analyzing error
• 00010025 - SCIS ROM communication error
• 00010026 - RTC communication error - click here for more info
• 00010028 - Head error - replace print head
• 00010029 - Unidentified NMI
• 0001002A - CR ASIC ECU error - Reinstall/update firmware
• 0001002B - PF ASIC ECU error
• 0001002D - Cleaning unit has reached end of life - replace cleaning unit
• 0001002F - 360 DPI writing time-out error
• 00010030 - Multi sensor error
• 00010031 - ASF phase detection error
• 00010032 - ASF drive switch error
• 00010033 - Eject phase detection error
• 00010034 - Eject movement error
• 00010035 - Pump phase detection error
• 00010036 - Type-B board installation error
• 00010037 - Head thermistor error - Replace print head
• 00010038 - Transistor thermistor error - Replace board assembley, main
• 00010039 - PG adjustment value incorrect overwrite error
• 0001003A - PG adjustment value outside range error
• 0001003B - Cutter installation error 1
• 0001003C - Cutter installation error 2
• 0001003D - Cutter installation error 3
• 00020000 - NVRAM error - Replace board assembley, main
• 00020002 - SDRAM error - Replace board assembley, main
• 00020003 - Boot program SUM error - click here for more info
• 00020009 - Flash memory SUM error
• 0002000A - Program load error
• 0002000B - The internal memory is insufficient
• 100000E0 - CPU address error (load)
• 10000100 - CPU address error (store)
• 10000180 - CPU reserved command code exception error
• 100001A0 - CPU slot undefined command exception error
• 100001C0 - The AC power is shut off
• 100005C0 - CPU DMA address error
• 10000xxx - CPU error
• 0003xxxx - Debug orode
• 0Dxxxxxx - An error code for debugging
• 0Exxxxxx - A time-lag of the RTC timer
Mar 24, 2018 | Epson Office Equipment & Supplies
Clear counter
How can i remove printer count?
Jul 30, 2013 | Epson Stylus Pro 7600 InkJet Printer
Giving me a Sevice Error 00010005
  • This error means there is a problem with your printers carriage operations
  • Check the carriage and the cartridges.
  • Remove anything that could be in the way of the carriages.
  • Check the cutter cap which if may also be a cause.
Thank you!
Sep 28, 2011 | Office Equipment & Supplies
Error message: Service Call Error 00010005
This code is usually appearing when the carriage for the print cartrige is restricted by any foreing object or by displacement one of the print cartrige that is rubbing on top of the cover,
Open the cover and make sure the carriage is free of anything try to move it manually to see what can cause this blocage Hope this answer your question Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 16, 2011 | Office Equipment & Supplies
Service Call Error - 00010005
This error 00010005 popped up when I was messing with my Print head for cleaing purposes.when I put the print head back into place the lever mechanism that is attached to the cutter blade detached from itself not allowing the printer to move the print head freely.below is a picture I scanned in from my Quick Reference Guide that shows how the mechanism should be. When I saw this I then realised what had happend and was able to put down the cutter blade to re attach the lever mechanism. After this I did not recieve the service code again and the print head was able to move freely. I hope this helps.
Oct 20, 2009 | Epson Stylus Pro 9800 InkJet Printer
Whene i start my 9880 it giveme a 00010005 error call service waht can i do to solve this problem? thank you.
Make sure there is nothing blocking the carraige (where the cartridges sit).
If there is nothing blocking it then the printer will have to go to an Epson service centre to be repaired as a part needs replacing.
Sep 03, 2009 | Epson Stylus Pro 9800 InkJet Printer
Help
Hello.
Here is a link for the online service request..
https://service.us.playstation.com/online-request.asp
Here is a link for phone support...
https://service.us.playstation.com/phone-request.asp
and here is the actual phone number and hours..
Contact Consumer Services
1-800-345-SONY (7669)
Monday - Saturday 6:00 AM - 8:00 PM Pacific Time
Sunday 7:00 AM - 6:30 PM Pacific Time
I hope this helps. Good luck!
Jul 29, 2008 | Sony Playstation 3 (PS3) Console
Epson Stylus Pro 9800 InkJet Printer Logo
1,563 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
