The computer died, and when restarted it won't even show the system bios/setup screen. Have determined that the monitor is fine. Will not boot to a CD or any other drive. Power supply shows lights, and CD drive receives power when turned on. The computer is approximately 2 year old HP a6300f. Other details:
Motherboard manufacturer's name: Foxconn MCP73M01H1
HP/Compaq name: Napa-GL8E
Is this a mother board failure?
DRJ
Motherboard or cpu failure. or possibly power supply.
I had a similar issue which was caused by the modem. I pulled the modem and all was fine. After that I decided to upgrade to a Cooler Master Case with a 500w PS and an Nvidia 9500GT 1GB video card. Also bought 2 Sony SATA DVD RW drives and replaced the slow HP drive. It's a screamer now. It used to be an m94040n.
Had this same problem a year ago. The factory hard drive has a known failure problem. Contact HP support to see if your computer is still under warranty, and if so, they will send you a new replacement.
djrengr - any luck on your prob? Same here. a6300f. Does not post, but all fans and periphs have power.
