Question about Samsung LN40A450 LCD TV
Black screen. screen doesn't turn on...and yes it is plugged in. cable is also plugged in and the batteries have been changed on the remote. we tried turning the tv on via the buttons on the side and this does not work either. When you unplug the tv nothing happens on the screen...it stays black. When the tv is plugged in...the screen still stays black however the little red lite on the bottom edge of the frame blinks. That is the only sign of life.
Posted by steph1172 on
Marvin
    Top Expert:
  • Samsung Master
  • 85,239 Answers
The TV is how do they say that "Kaput"
Posted on Jun 22, 2017
5 Related Answers
kom_computer
SOURCE: Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Posted on Sep 27, 2008
Jim Krause
  • 1779 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
Main Bd part# BN94-00629F and sells for $201.00 that includes a 50.00 dud. Encompassparts.com
Posted on May 10, 2009
Anonymous
  • 41 Answers
SOURCE: Tv picture freezes then goes black 10seconds later HL-R5067W
Sounds like the digital board needs replaced.
Posted on Jul 11, 2009
Anonymous
  • 15 Answers
SOURCE: 50 inch Plasma Samsung HP-T5054 appears to have power however...
check the power inverter on the power strip. also check the caps on the board and if any of those caps have a round top it is bad and needs to be replaced. i hope this helps.
Posted on Jul 28, 2009
Anonymous
SOURCE: bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Posted on Oct 27, 2009
Trying to change source, PC appeared in upper left corner, black screen, message "change signal cable." Can you help?
disconnect the PC cable going to the tv , the VGA has a priority and will take over til another device is plugged in , make sure other devices are plugged in and turned on , i can be more helpful if you give me more info , the more the better... ill keep an eye out.
Good Luck ,, The Cable Guy...
My Veon 32" tv wont turn on
Help my veon tv power is on sound is work but the screen is black ..i dont know what to do ?
5helpful
Remote control won,t work
This is how to complete a remote reset for a Sharp television:
Turn off the television if it is on. Unplug the television. Please leave it unplugged. Take the batteries out of the remote control. Leave the batteries out of the remote control. Is the television still unplugged? Yes? Good leave it that way. Are the batteries still out of the remote? Yes? Good leave them that way. Point the remote at the television's remote sensor. Hold the power button down for 30 seconds. Release it. Press and release each button on the remote control. Plug the television back in. Turn it on with the power button on the television itself. Replace the batteries. Try adjusting the volume. Hopefully the remote works. If it still doesn't work the remote sensor on the television could have gone out or you may need a new remote. http://www.sharpusa.com may have a remote you can order or http://www.replacementremotes.com but if that isn't the problem you may or may not be able to return the remote.
My packard bell won't load windows. When i turn it on the packard bell logo appears and then a black screen with American Megatrends appears with which Function keys to press and at the bottom of the...
try to change your cmos battery,and first boot your hardrive,and set your time and date properly then save your settings take a look if your settings will be save.if yes,that means your cmos battery is the isue.
4helpful
2answers
My remote stopped working, I changed the battery but it still doesn't work.
have remote checked out at advance auto,could be ur keyless entry sensor bad
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Black rectangular box on screen from doing menu
Take ur tv remote go to menu check the captioning functions turn all CC1,2,3 off and all txt off too.Yes,text functions is on,that why u getting a big black block flashing on ur screen.
2answers
Remote doesn' turn n tv or chane channels
try changing the batterys. If its a universal remote reprogram it again.
Samsung LN40A450 LCD TV Logo
Ekse
Demonic-2011
Demonic-2011
