Hi, turn on your ds lite. Very bottom middle of screen touch icon to get into settings, touch pink spanner icon, them the bottom left icon looks like a football. Touch english. Job done Enjoy
Turn off the Nintendo DS, and place it on the charger. Leave
the device for 45 minutes to allow it to gain a full charge, and then
power it back on. Weak Nintendo ds lite batteries may cause screen flicker.
Turn off the DS, and remove all game cartridges. Turn the system back on to launch the main menu.
Click the small sun icon to open the brightness menu. Adjust
the brightness level using your stylus. Turn it up to max to improve
back lighting.
Check that the Nintendo DS is open and in the locked position. It must be open to its default position to operate properly.
Turn
on your DS and navigate to the WiFi connection settings menu. On a DSi,
click the wrench icon, navigate to the third page of options and select
"Internet." On an original DS or DS Lite, select "Edit WiFi Settings"
from the in-game menu. The game must be WiFi compatible to access the
WiFi settings menu.
Select "Connection Settings."
Choose an open connection slot, which will be indicated by the word "None" next to the connection number
Select "Search for an Access Point."
Select
your wireless network from the list displayed. Enter the wireless
encryption code for your network with the onscreen keyboard.
Select "OK" when prompted to save your settings and establish a connection with the network.
Turn the DS on without a DS card inserted (or with Auto mode turned off).
Touch the DS icon in the bottom middle of the screen.
Press the far right yellow icon.You will then be taken to the calibrate screen.
Touch the small red squares on the screen as they appear.
Press Confirm amd exit menu.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer. If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
If you would like to calibrate your screen... Turn the DS on without a DS card inserted (or with auto mode turned off). Then touch the DS icon in the bottom middle of the screen. Press the far right yellow icon, with a crosshair in it. You will then be taken to the calibrate screen. Touch the small red squares on the screen as they appear.
First, go to the Settings Menu (the small DS icon at the bottom in the main menu). Then click on the first, pink icon with a white wrench on it. Press the icon with the sphere-like shape on it. Finally, select the language you want. Press confirm and you're done!
You
can play multiplayer games with a Nintendo DS Lite even if you don’t
possess a copy of the game. If one of your friends has a multiplayer game card, they can use their Nintendo DS Lite as a host for the game session and you can join the multiplayer game.
jQuery('.intro .thumbnail').each(function(i,e){
jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); });
Things You'll Need:
Nintendo DS Lite
Using One Card to Host the Game
Step 1
Look on the game’s
packaging for the "Multiplayer" icon. If the game requires only one
player to have a copy of the game, the icon will show two DS Lites: a
DS Lite with a black screen transmitting waves to a DS Lite with a
white screen. Below the two DS Lites is a range of numbers which
indicates how many players the game can support.
Step 2
Put the game card in the Nintendo DS Lite that is acting as the host for the multiplayer game session and start it up.
Step 3
Have
the other players turn on their systems. They will use the main menu
screen to access the "DS Download Play" icon. They need to tap the icon
to begin downloading the game information from the host DS Lite.
Step 4
Begin playing when all of the systems have finished downloading the game information from the host.
Multiple Cards for Multiple Players
Step 1
Look
at the "Multiplayer" icon. If every player in the game session needs a
copy of the game in order to play, the icon will show two DS Lites,
both with black screens, transmitting waves toward each other. A range
of numbers is under this graphic and indicates how many people can play
at one time.
Step 2
Read
the game's instruction manual on how to set up the game session. The
steps required vary by company and sometimes by title within the same
company.
Well go to a nearby GameStop they fixed my DS lite when it wouldnt charge with the charger the reason was it was old so i needed a new one anywhoo when the screen comes on it says NENTENDO DS LITE well mine says lite since it is a ds lite well you tap the screen with your pen and the menu is there or this could be because you (A) dropped it
(B) got it wet
(C) handled it roughly
hope this helps
~Queen of Spades
When you power up, make sure you don't have a game in to the unit. When the Menu screen comes up, there should be an icon in the bottom left corner that looks like a sun. Pressing this icon should allow you to change the brightness setting.
Hope it works!
Olivia~*
If the light on the lcd on the top is green and your text on the bottom is faded, get to the main ds menu (where the pictochat,ds download play, and the game.) and look on the bottom left, There you bwill find a sun shaped icon, touch this icon and it should contrast the light. (or the f4 fuse busted).
