If you have Tried Unplugging the Unit as well as you are sure that there is no Clogging in the Hose or the Pump, it sounds like it is Defective Control;Board.
Now. i have seen People calling Electrolux and usually they would either replace the hose or tell you to check filter or so or offer you a Leak Repair Kit which might not Solve the Problem as you do not have any Leak or Clogging. In the end, they would also accept that it is Faulty Control Board and Needs Replacement.
It is advisable that, if it is under Warranty, get it replaced directly by Company. If not, then you need to take a Wise Decision whether it is a Time to Get it repaired or time for a new one.
I could only advise you, if the Dishwasher is more than 4 years old and the cost of repair is more than half of the new one, then i should recommend you to go for new one unless Repair Makes sense.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Unplug it for an hour or so and it should reset itself
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
Hi
"Er Clean S" is a common error with Frigidaire which means
shorted keypad. The issue is with the touchpad/keypad that should be replaced.
However, before replacing the keypad you can unplug it and take it apart
completely and use a hair dryer to blow some warm air on the keypad assembly to
blow the moisture off. Hope this helps...please post back for further
assistance.
Daniel
We are going to try this. We'll let you know.
Thank you and Merry Christmas!
It's been several hrs. We plugged it back in, same ER 01 message flashing.
Any other suggestions?
please see the problems we are having with our Electrolux Dishwasher and please advise.
We tried turning off the breaker to the unit for over this did nothing.Then we unplugged the unit from the wall and it reset itself but will not start. This dw is only 1.5 years old. So we need to decided what to do with it.
