Samsung DV218AEW Electric Dryer Logo
Question about Samsung DV218AEW Electric Dryer
Dryer timer keep resetting..keeps running and
Dryer times keep resetting..keeps running and resets time
Posted by swgw50 on
3 Related Answers
Anonymous
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
Anonymous
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
Anonymous
  • 180 Answers
SOURCE: I have a Samsung
The belt slipped off the pulley. There is a switch to keep the drum form starting if there is no tension on the belt. There is a service bulletin on most samsung dryers to install a bigger motor pulley to keep the belt from slipping off. Contact your local samsung service provider, or samsung directly and they should take care of it for you.
Posted on Jan 30, 2011
1helpful
I have an Intermatic model ET 100C That keeps going into error mode also have to keep resetting the time of day on it.
Copy following link for manual and resources:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
If you changed battery and done reset protocol, then timer has gone bad.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
The timer on my Maytag DG212 dryer sticks and does not advance so it just keeps running.
You will need to change out your timer, as it is non-repairable.
Hint:...Be sure to get the same brand/mfg of timer, or be somewhat of an electrician because if you do not get the same timer it will not be wired the same.
Also only remove and replace one wire at a time, it will keep you out of trouble and ease the installation of the timer.
Please rate me
I keep pressing NEXT/ON/OFF and RESET to reset the
Review instructions:
Instructions say hold down Next ON/OFF > and push Reset > then release Reset > but keep holding down NEXT ON/OFF until screen flashes 12:00 >> after that, you release NEXT ON/OFF
If that doesn't work:
Timer functions are powered by battery, not by electric circuit, so your wiring is not cause of this problem.
Try removing battery for longer than 5 minutes.
This will reset time/date but not your programs >> the programs stay in the timer forever until reset.
Then try the reset procedure again as shown above.
If timer still doesn't reset:
EJ500 has a 1 year limited warranty.
You may need a new one.
Dryer will not stop.Keeps running. Can hear the timer motor all the time.
If timer will not shut of on timed dry replace the timer.
The motor gears are stripped and are unrepairiable.
6helpful
3answers
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
Replaced timer module. Dryer did not run.
Check the voltage across the timer motor, make sure that you have 120 volts. If you have 120 across the timer motor, then it is bad. Also check your wiring to make sure you have wires in right place
Timer not moving on clothes dryer
You need your timer switch tested and replaced.
Apr 03, 2009 • Dryers
3helpful
Mar 25, 2009 • Dryers
1helpful
2answers
Timer does not advance, dryer keeps running.
in auto dry the timer motor receives voltage to advance by way of the cycling thermostat.[each time the thermostat opens to stop the heat the switch in the thermo then changes that voltage up to the timer and it will advance timer motor until it closes again for heat and this continues till clothes are dry]so as long as timer is receiving that voltage and not advancing then i agree its the timer.other wise it could be a failing/intermident cycling thermostat.a thought.in timed dry the timer motor receives constant voltage.so if never stalls in timed dry it may be a clue that the timer is ok. i hope this helps you understand whats going on. God bless ,tom
Jan 23, 2009 • Dryers
1helpful
Timer problems
Yes it probably is but check the keypad also.It could have a short in it.
Top Samsung Dryers Experts
Marvin
Marvin
Mike
mark warfield
mark warfield
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
