Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer Logo
Posted on Dec 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drum is not turning
Maytag Bravo
Jose Pino
Level 3:
  • Master 563 Answers
  • Posted on Dec 24, 2009
Jose Pino
Master
Level 3:
Answers
563
Questions
0
Helped
133174
Points
1604
If the machine turn on and appears to heat properly, It usually happen when the belt breaks or gets out of the pulley. A more serious issue may be the motor broken.
1helpful
Maytag Bravo gas dryer gets too hot.
Most likely needs a new thermostat. Go online to find instructions on replacement. Make sure it is unplugged. I don't think it is too difficult to do yourself.
Maytag bravo mvwx500xw does nothing lights come lid locks then nothing
check the inlet hoses are connected and tap is set to on.
Bravo 2012 gas dryer control panel
I have the same dryer. My control panel went dead today too. Light in drum works just fine. Nothing working at all on the control panel.
Maytag Washing machine; Bravo,not filling up with water.
what is your model number is then we can get started okay
How do i get the change out of the drum of bravo 300
I'd try laying in some double sided tape...not pressed in there but just make ya a loop down at the bottom and run it in the spin cycle a few seconds..
If the coins come out, maybe they can catch on the tape.
7helpful
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Installed new gas Maytag Bravo yesterday. It will
is the gas on
sometimes these units get dropped if they fall hard you could have cracked the ignitor
Accessing burner and installing LP conversion on Maytag Bravo
you need to obtain a jet (orifice) of the correct size for the gas you wish to use. remove the burner and, replace the existing jet; that is all there is to it.
My maytag bravo top loader washer is displaying a code of LF and
it meant "low flow" check water connecting lines. mine has the same problem.
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
