Question about Hotpoint RGB745 Gas Kitchen Range
I just bought a home with a hotpoint self cleaning gas oven but do not have the manual. How long should the oven run to clean? Can I use soapy water to wipe the interior instead of running the oven?
Posted by lillymac17 on
Anonymous
    New Friend:
I have a hotpoint electric autoclean oven, how long before the door lock releases? I do not have a manual, the oven is about 5 years old.
Posted on Jan 24, 2010
Oven ( with combined grill) is very smokey and smelly
Your oven is one of the most-used appliances in your home, and when you use it for preparing strong-smelling meals, like fish or for curing jerky for instance (I speak from experience on the latter), you can be left with an oven that emits bad smells into the rest of your food for weeks on end. You have a spill in the oven. Wait until the burners are cool to clean them only with warm soapy water (no chemicals) and clean inside the oven. Like a self cleaning oven, it's only at high degrees it will "burn" off the food spills and will cause smoke. Shop Appliances and Furniture for your home from Appliances connection online store.
Jan 07, 2014 | Hotpoint Ovens
I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
hello,
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
    Here are some solution on how to unlock the door of your oven ans do self cleaning below.
    IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
    hope this helps you out please rate this solution it helps get better results for our customers like you
    Self Cleaning
  • Fast Cleaning
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    My self cleaning oven will not lock, so I am assuming it is broken. My oven needs to be cleaned. Since you can not use an oven cleaner on it, what can I use to clean it?
    HELLO,
    Please carefully apply the below instruction to clean up your range
    self cleaning solution
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    thank you.
    Sep 20, 2010 | Hotpoint RB757 Electric Kitchen Range
    Grease-encrusted cast iron trivets
    Try soaking in hot soapy water that you've dropped several denture cleaning tablets in. That's helped me get some tough stuff off, or at least loosened up enough that some elbow grease and a scrubbie can finish off the job.
    Put them in the oven and run the self clean cycle
    Oven cleaner. That stuff is second only to industrial grade hydrogen peroxide
    Batender's Friend. That stuff is amazing!
    Good Luck
    Jul 31, 2010 | Viking 31 in. VGSU101 Gas Cooktop
    Self-cleaning feature
    Check your owner's manual, but most self-cleaning ovens should not be cleaned with chemicals. The finish can be permanently damaged. You might try running the oven through the self-cleaning cycle more than once. It will take some time. Make sure the room is ventilated properly since the cleaning cycle produces a lot of heat.
    Jul 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    What do I clean my 60" garland double oven with?
    Use warm, soapy water for everyday cleaning, and dry with a soft cloth. Use a mixture of 25 percent white vinegar in water to remove mineral deposits left by hard water. Step3Remove burned-on food, wash with warm soapy water and a scrub brush made of nylon. 4Remove rust with an oxalic acid cleaner such as Bar Keepers Friend 5 Use glass cleaner and a soft cloth to remove fingerprints. Polish stainless steel with a paste made of water and baking soda. Rinse and dry thoroughly. Please rate this fixya
    Jan 28, 2009 | Garland H283 Gas Kitchen Range
    Self cleaning oven instructions
    you can google it or just push the clean button and it will most likely default to 3 hours and all you have to do is push start and after it is done wipe out the ashes with warm soapy water DO NOT USE OVEN CLEANER as this will destroy the finish of the self clean cavity
    Nov 12, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    Cleaning the cast iron grates and griddle
    Try This....
    Place the grates in a sink of hot, soapy water and let soak for 15-20 minutes. For tougher stains, add a cup of sudsy ammonia to the water. Make sure grates are thoroughly dried after each cleaning. After the cleaning process, Lightly coat the bottom of the grates with a cooking spray and then blotting them dry.
    Or
    If you self clean the oven on occasion, put them in the oven when running the self clean cycle.
    Jun 22, 2008 | Frigidaire 30" Self-Cleaning Slide-In Gas...
    Hotpoint RGB745 Gas Kitchen Range Logo
    415 people viewed this question
    Top Hotpoint Kitchen Ranges Experts
    Ismael Rodriguez...
    John Tripp
    John Tripp
    Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
