Question about Uniden Cordless Phone EXAI985
I don't get a dial tone when I pick up the phone both the base and the extention both are dead but I have a fax machine also on another line and it works ok
Posted by janice_barry on
Anonymous
    Problem Solver:
  • 12 Answers
To test the phone system. unplug the phones that are not working from the telephone jack. Install a phone on that phone jack that you know works (an old one or a cheap new phone). If the new phone works on the phone line in question, then your cordless phones are the problem and not the house phone line. If you plug the known working phone into the wall and it now does not work, then you have a problem with the wall outlet or the connection to the house. If it is a phone line or house connection problem, call your phone company. If it is your cordless unit, try them at a different phone outlet or at some other house to see if they work anywhere.
Posted on Jan 28, 2010
Hi my canon fax-JX500 displays 'line in use' and has no dial tone. Can you please tell me how to fix the problem?
Unplug your fax from the phone line. Plug in a phone. Dial tone? Yes? then either fax is bad or the phone wire is bad.
No dial tone? Phone line dead.
Aug 30, 2015 | Canon Office Equipment & Supplies
How do i get dial tone on fax machine
first, as a tech, i would make sure your phone jack works, then also make sure the line is plugged into the "line" jack on rear of fax. if those two steps are verified beyond a doubt, press your "hook" button and listen for dail tone. if none, pick up handset and listen. if you get tone on handset, then your speaker is disconnected. if you don't get a tone either way, then chances are you have a bad "NCU" board.
good luck,
razors
Oct 19, 2011 | Brother MFC-8220 Fax
I have a dial tone coming out of the jack on the wall that is only for this fax machine but the fax machine is saying phone off hook.
,Line should be connected to directly to printer line in port, parelall phone should be connected to extention port,don't split the line for printer & phone. Telephone line voltage should be 48V with/without line connected to the printer, if any voltage differce replace LIU card..
Sep 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Unable to send or receive faxes
Fios is the problem. All fax machines are analog devices.
Apr 14, 2010 | Brother IntelliFAX 3750 Plain Paper Laser...
Fax is not going out and no signel in the receiver
Plug a compatable phone into the wall socket to see if you can get a dial tone.If not contact your phone company.If you get dial tone then check that you have the phone lead plugged into the line socket on the fax machine and not the extention or Tel sockets.
Oct 21, 2009 | Samsung Office Equipment & Supplies
Hi i cant send a fax
First thing is to ensure that you have dial tone by picking up the handset on the fax machine and listening for dial tone.If there is no handset take a standard house phone and plug it into the jack where the fax machine was inserted. If there is dial tone on the phone then I would advise you to turn the power off the fax for two minutes then power back on. If there is no dial tone on the phone line contact your vendor or local phone carrier and report NO DIAL TONE
May 30, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
No dial tone
Sounds like the phone line may be dead, try to put another phone on that line and make sure the phone line is active.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Fax machine wont send or reiceve
Check to see if you have a dial tone. If not, plug a regular home phone into the jack in the wall and see if you can call it or dial out. You might have a dead phone line.
Apr 22, 2008 | Office Equipment & Supplies
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
INTELLIFAX 2820 NO FAXES COMING THROUGH
Oops, I disconnected from the chat with you after I said I would stay connected. If you have any other questions, feel free to ask them here. Just for our knowledge base, in case anyone else has this problem - it turned out to be a short in the phone line. When picking up the handset connected to the fax machine, there was no dial tone. When connecting the fax machine to another phone line, the dial tone returned. After swapping out the phone cord between the wall and the fax machine to be sure that wasn't the problem, Jriedel is now talking to the phone company about it.
Sep 12, 2007 | Brother IntelliFax-2820 Laser Fax
Uniden Cordless Phone EXAI985 Logo
200 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
