Question about Kodak EasyShare 8" LCD Wi-Fi Digital Photo Frame
I have a kodak easy share photo frame and don't know how to transfer pictures from my computer to my photo frame
Posted by jrevel30 on
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
Make sure you have installed the Kodak digital display Software then you can just drag and drop the pic to your pc or vice versa
Posted on Jan 08, 2010
Have downloaded ap for kodak easy share c1550, can't transfer photos to computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 31, 2013 | Kodak EasyShare One Digital Camera
Downloading pictures into Pandigital
does it have a usb slot on the frame or a memory card?on the frame
Jul 07, 2008 | Kodak (0041771525088) Lens Adapter
I am attempting to transfer photos from my C713, but I can't power the camera on when it is plugged into the USB. I have changed the batteries and the camera will power on when the USB is disconnected...
Easy shares are set up so they won't respond when plugged in to usb. When you turn the camera on and then run the easyshare program and lastly connect the usb cable, then the pictures and video will transfer to the computer.
You can also take the SD card out of the camera and put it in your computer and transfer pictures that way as well.
Nov 10, 2010 | Kodak EasyShare C713 Digital Camera
Images from memory stick will show on frame but
Try these steps: 1. Insert the card.
2. Tap on MENU.
3. Select PICTURES and tap on OK.
4. Highlight SD/MMC and hit OK.
5. Once you see the thumbnails of the pictures, tap on MENU again.
6. Scroll down to MULTI-SELECT and hit OK.
7. Tap on MENU and scroll down to SELECT ALL and hit OK.
8. Tap on MENU and scroll down to COPY and hit OK.
9. Highlight INTERNAL MEMORY and hit on OK.
Dec 18, 2009 | Kodak 8" LCD Digital Photo Frame
Can't transfer pictures to computer
First start easy share program, than turn on camera, then plug in to usb
Jul 01, 2009 | Kodak EasyShare C340 Digital Camera
Will Not View All Pictures In Photo Directory
Take the camera and tag the pictures and select all of them and tag/ favorite and protect and tag some more directories you can create. That will delay transfering the pictures but all of them will transfer to files.
Vitally
Mar 01, 2009 | Kodak EasyShare EX1011 Digital Picture...
I can't transfer photos from Adobe to digital frame
The Kodak S510 does not have a built-in internal memory. You can hook it up on your computer using a USB cable with a USB OTG connector and copy the pictures from your computer to the inserted memory card or a USB flash drive in the frame.
Also, make sure that your photos are in JPEG format.
Feb 07, 2009 | Kodak EasyShare One Digital Camera
Downloading photos
If you are using Windows XP unplug your camera from your PC and uninstall the Kodak software. You don't need it to transfer photos to your PC. The next time you connect your camera (turn the camera on) to your computer it should recognize it and you can use Windows built in transfer software. Details are here:http://www.organizepictures.com/2006/11/5-easy-steps-to-transfer-your-pictures-using-windows-xp-photo-wizard
Jan 21, 2009 | Kodak EasyShare V1003 Digital Camera
Transfer from computer to memory card
http://wwwuk.kodak.com/global/en/service/downloads/dln_ekn029310.jhtml?pq-path=3906/2308/2316
you haveto install driver from above link..and then try to transfer photos from camera to pc...
after that from pc you can transfer to photo frame...
Jan 07, 2009 | Nextar N7 - 7 Digital Photo Frame with...
Kodak easyshare camera not transfering photos
My kodak easyshare camera will not transfer my photos to the computer. Everything is plugged in and the camera is blinking but nothing is happening. Please help. I checked the connections, they are fine.
Nov 01, 2007 | Kodak EasyShare One Digital Camera
Kodak EasyShare 8" LCD Wi-Fi Digital Photo Frame Logo
175 people viewed this question
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
