For Fujitsu C2230 Notebook PC's with either Windows 2000, or Windows XP, right here on Fujitsu Support,
http://support.fujitsupc.com/CS/Portal/supportsearch.do
Whoops FAILED! Tried to give you a direct link to the Drivers page.
(Have you ever seen those vid's of Failed? Like the skateboarder who went down the pipe railing, and wound up straddling it?
Ummm, ..err,...Never mind!)
Let's go the long way instead.
http://support.fujitsupc.com/CS/Portal/supporthome.do
On this page go to the right hand column, and under the white - Mobile Support - heading, left-click on - Driver Downloads
On this page you will see three headings at the top.
Select Product
Select Series
Select Model
Under Select Product click on - Notebook
Now under the Select Series heading, scroll the side bar down, and click on - C Series
Finally under the Select Model heading, click on - C2230
Click on Go, to the right of the arrow in the red square.
You will see the - Windows 2000 Compatible Drivers - heading, and
Windows XP Compatible Drivers - heading.
Go to the operating system you are using.
Left-click on Audio
Click on Accept on the next page.
In the small window that comes up on the top right, left-click on -
Save File.
If you do Not have your downloads, set to save to your My Documents folder, this file will go to your Desktop screen.
(My Documents for Windows XP. Documents for Vista.
Windows XP? Click on Start>My Documents)
The name of the file is C2230_AUDIO_REALTEK_V5.10.00.3696_2KXP.EXE
When you see the file name, Double-click on it.
The Installation Wizard will come up.
Follow the easy instructions.
(Basically just click on Next, Next, and Finish.
If you are asked to restart your computer, do so.
If you are not asked to restart, close all windows until you are back to your desktop screen. Restart your computer.
Start>Turn Off Computer>Restart)
The above, is stated that you are using your Fujitsu Lifebook C2230, to download the Audio, (Sound) driver.
If you are using another computer to download this Audio driver, download it to the computer, then right-click on the Audio file name, and burn it to CD disk.
Take the CD disk, and install it in the Fujitsu Lifebook C2230 optical drive, with the laptop on, and Windows loaded.
If your Fujitsu Lifebook C2230 has Windows XP, left-click on Start, then My Computer.
Double-click on the optical drive that the CD is in.
Follow the easy instructions of the Installation Wizard.
If you have problems, or further questions about this, post it in a comment.
