Question about Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier
My vaporizer is barely putting out any steam...is there a way to clean this unit so that it will produce more steam? This is a Vicks 1.5 gal unit.
Posted by jm0nac0 on
Anonymous
    New Friend:
  • 3 Answers
Is the water in your area soft? If so, add a few pinches of salt. Vaporizers boil the water by running electricity through it. If your water is too soft, no electricity and therefore no steam.
If you have hard water, and the unit must be cleaned, try soaking it in vinegar.
Posted on Jan 14, 2010
WHERE CAN I BUY VICKS WARM STEAM VAPORIZER
Problems in a Vicks Warm Steam Vaporizer comes when it is mis-handled or when we buy non-warranted products. It is the best solution to spend money on the branded and cheap vaporizers.
http://www.vaporizerchief.com
Cheap Vaporizers Herbal Vaporizers For Sale
Jan 21, 2014 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I had left my vicks vaporizer with water in it for like a month or longer and barely cleaned it out and now it doesnt work no steam or nothing will come out wats wrong is it broken???
The problem is more than likely due to a calcium and mineral build up in the tank and the tubing.
Hopefully, it's not to late to do something about it. So follow the instructions below,
Unplug the unit.
Remove any remaining water from the tank.
Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water (enough to fill the tank) and pour the solution into the tank. Allow t to sit overnight. In the morning, plug the unit in and turn it ON. If it doesn't start producing steam, turn the unit OFF, unplug it and empty the tank. Mix more solution as described above, pour it in the tank and allow it to set for 3 or more hours. The plug the unit in and turn it ON. Hopefully, this time, it will start to produce steam. If it does allow it to run until the tank is half empty. Turn the unit OFf and empty the remaining solution from the tank. Refill the the tank with Bottled Distilled Water and run the unit until it's empty. That will flush the system.
In the future, I would highly recommend the use of Bottled Distilled Water, rather than using tap water.
If the above didn't solve the problem, it's time to buy a new humidifier and use Bottled Distilled Water in it.
Jul 19, 2011 | Vicks Humidifiers
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I need to know how to use the warm steam vaporizer i lost the instruccions..
you add vicks petroleum paste/jelly at the top where the air vent is. Add 1-2 tablespoons of salt with tap water in the tank, plug in the unit and warm steam will produce.
Feb 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My humidifier is not working. I have cleaned the heating element. When plugged in the green turns on but that is it. The elements are not heating up to begin the vapor process.
Add salt. No more then 1/2 to 3/4tps max depending on the mineral content in your area.
The unit has two electrodes dipped into the water. Since water its self is none conductive without heavy minerals such as iron and such. You will have to add a small amount of salt until current starts flowing between the electrodes. I suggest a small pinch of salt each try until it produces the steam effect you desire.
Dec 22, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I bought our Vicks vaporizer and it worked great the first night we used it. We had added a pinch of salt and it steamed all night. Now my husband is sick and we cannot get it to work correctly. We added...
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Dec 16, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
No steam output
Dec 06, 2009 - found solution: if unit is truely clean, unplug unit then mix about a teaspoon of iodized salt (table salt) to the water. Reconnect unit wait about 1 - 2 minutes, unit will start to make a grinding sound but shortly after steam will produce.
Nov 13, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks steam vaporizer
i do apologize for the inconvenience but the unit will need to be cleaned by hand or you can go to a local hardware store and get a solution that you put in your water to help kill the residue. it's basically from your hard water. now if you do it by hand you will need to get a soft toothbrush. you'll have to scrub the coils. then rinse the particals away. now doing this the unit needs to be turned off and cooled. after you do the cleaning you can run it like normal. if you have any other concerns or questions please feel free to ask.
Jun 11, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier Logo
2,586 people viewed this question
Top Vicks Humidifiers Experts
Brad Scarpetta
Paul Carew
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
