Question about Microsoft Xbox 360 Controller
Controller wont sync with 360 - Microsoft Xbox 360 Controller
Posted by balla4u12345 on
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
Have you synced it? Try visiting my syncing tip to synccontroller wont sync with 360 - 2_bing.gif it properly.
http://www.fixya.com/support/r3915841-sync_xbox_360_wireless_controller
If that doesn't work you may have an internal controller error and your best bet is too replace it. You can also call Microsoft and explain the problem before you trash it.
Posted on Jan 26, 2010
MY CONTROLLER WONT CNNCT TO MY XBOX EVEN WEN I SYNC IT . ITS BRAND NEW.
You might have to replace the batteries in the controller, as if the battery life is low the controller will have issues syncing to the xbox 360. Just in cause, To sync the controller to the xbox 360, you must turn on the controller using the xbox guide button and then press the Wireless Sync button right next to the Controller Charging Port. Then you must press the sync button on the xbox 360. You must do this semi-quickly, or the sync process will not complete.
Lastly, You also might have a faulty controller, I suggest you go back to the store you got it from and see if they will replace the faulty controller.
Xbox 360 Controller: My xbox 360 controllers wont sync at all no matter...
Try replacing the batteries in your controller. If this does not work then try the controller on another console. Failing this your controller is broken.
Best recommendation is to buy a wire and use it wired.
Won't connect to xbox 360
Have you synced it? Try visiting my syncing tip to sync2_bing.gif it properly.
Contoller wont conect to x box 360 and lights just flash with new batteries
Have you tried re-syncing the controller to the Xbox 360?
Press the small button right beside the expansion port located on the front of the controller. Then press the button located to the right of the memory expansion ports on the Xbox 360 console. This should re-sync your controller.
Hope this helps,
Bill
2helpful
Xbox wont sync with my wireless contorller
Have you ever synced one of these controllers before?
Hold the controller in your hand as if you were playing a game. Next flip the controller up so that the buttons on it, are facing you.
There is a small white button that you will see. Power your xbox up and after you get to your main menu press the sync button located about 2 inches to the left of your main power button on your console.
Press the described button on the console and then the described button on your controller. The two should sync together perfectly fine.
Xbox 360 wireless controllers wont connect!
well you might want to press the little button by the battery pack at the top and the little one on the 360
Xbox 360 controllers wont connect
If you have tried using the white sync button (on top of the controller) and the white sync button (in front of the 360) the RF module in the 360 needs to be replaced. It is a very simple process, take the 360 apart and 3 screws T9 are holding it in.
Even when i press the sync my controllers still dont connect
what you do is turn on your 360 and controller and press the white connect button and your controller
should connect
Microsoft Xbox 360 Controller Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
Joseph Murphy
Joseph Murphy
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
