Nova Development Photo Explosion Deluxe Version 3 Logo
Question about Nova Development Photo Explosion Deluxe Version 3
I installed my Photo Explosian Deluxe version 3 on a new laptop we purchased that has Windows 7. The program will not launch - says not reponding when look at task manager.
Anonymous
    New Friend:
I found some freeware that detected and restored my files.
Posted on Dec 24, 2009
Program does not load nor respond...it is deluxe 3 my system is win7
It might not be compatible with windows 7, you could try running it under windows xp mode . Right click on the program launch icon and do the following:
2answers
I have a new computer with 'Windows 7' installed. I would like to run 'Print Shop Deluxe 22' Is there a patch to make the program work? I need a simple fix. Hope someone can help me. Cheers.
You can use the Windows Vista Compatibility patch which works equally with Windows 7.
You can download it here.
When the download is complete, close the Download window. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update. Then follow the onscreen instructions to complete the installation.
After the patch being installed, you can
launch and use The PrintShop® 22.
Hope this helps!
MPEG vio driver error I have taken it out and reinstalled it again but get same message .i recently bought a laptop with windows 7 can you help me please . thank you sandra
Welcome to Fixya. Have you tried running the software in Compatibility Mode? Depending on your version of Windows 7, you may have the ability to run it in Compatibility Mode. Try right-clicking on the Photo Explosion shortcut that is on your Desktop. Then, go to Properties from the pop-up menu. Then, select the Compatibility tab. On that tab, put a check next to "Run the program in compatibility mode for:". Then, select Windows XP SP2. Click on the OK button to save this setting. Finally, try launching the program again.
If you have questions please let me know. Thanks for using Fixya.
Photo explotion will not open after i use it one time. i have to uninstall and reinstall it to use it,it worked fine with windows vista but i now have windows 7
2helpful
My program photo explosion deluxe version 3 will not opened when downloaded to my new computer that operates windows 7. what should I do to get this program workining, I do not like version 4 of photo...
Hi!
What I understand is that your photo explosion deluxe is a windows xp software. Since it is not working readily out of the box in windows 7 then what you could do is install windows xp mode for windows 7. Windows xp mode allows xp software to be installed and windows 7. What you need to do is just download windows xp mode and install it. After which you could then install that software on there. Just make sure to uninstall your current installation of photo explosion deluxe before you do this.
Here is the link to the download for windows xp mode: http://www.microsoft.com/windows/virtual-pc/download.aspx
And Here is the link to some of their videos on how to use xp mode so that you could understand further how to set it up: http://www.microsoft.com/windows/virtual-pc/support/default.aspx
If you have any more questions or concerns please feel free to come by again here at fixya.com
You have a great day.
1helpful
I used Photo Expl 2 on my previous (XP) computer, but recently upgraded on a new computer to Windows 7 Home Premium. Had a problem with Photo Expl 2 on Windows 7 Home Premium, and I see by posts that...
Here's one from left field,
Download this photo app. It on all new customer's software builds.
http://www.faststone.org/FSViewerDetail.htm
After that, yes, there is an XP Mode available for free download to users of W7 Pro, Ultimate or Enterprise and would run your previous more "friendly" version.
Best Regards,
TheSelkie
I have Photo explosin 3 on my computer it will not work correctley I have windows 7. It keeps freezing or not opening,
Hello!
I'm Richard from SoftCity Cafe, the new home of Photo Explosion's tech support. I spoke with the tech support reps about PE 3 and its compatability with Windows 7. Unfortunately, only some aspects of the program work in Windows 7 and the recommended solution is to upgrade to version 4. I can tell you that there has been a request of the PE development team to release a patch for Windows 7 compatability, and if this is something you are interested in I would recommend leaving a message in this thread on SoftCity:
http://cafe.softcity.com/questions-answers/view/1cDMxMzN/please-help-photo-explosion-deluxe-version-3-is-much-better-than-version-4
Hopefully this will help you and users like you.
Cheers,
Richard
MPEG VIO Driver Error photo explosion special edition 3.0
How to correct a Load MPEG VIO Driver Error in Windows Vista.
If you are experiencing this issue with Windows Vista, please follow these directions:
Note: These steps are only for Windows Vista. If you are experiencing the problem on Windows XP, please see the directions found here: KB Article 1469
1. Uninstall Photo Explosion 3.0.
2. Reinstall Photo Explosion 3.0.
3. Restart the computer.
4. Download the Vista update for Photo Explosion 3.0 from the following link:
http://www.novadevelopment.com/Support/Updates.aspx
Note: Please make sure you download the correct one for your version of Photo Explosion 3.0. If you have the Deluxe version, download the Deluxe update. If you have the regular version, download the non-Deluxe update.
5. Save the update to an easily accessible location, such as your Desktop.
6. Once downloaded, go to where the update was saved and double-click the update.
7. After installing the update, you should no longer experience this problem.
Note: It is extremely important that you do not run Photo Explosion until you have restarted the computer and installed the update. If you run the program before installing the update, you will need to start the steps over from the beginning.
This comes directly from the Nova FAQs. Hope this helps!
Can i install photo explosion deluxe version 3 on 7?
Photo Explosion 3.0 requires: Windows 2000, XP or Vista,Pentium III or Faster ,128 MB RAM ,CD-ROM Drive .It wont work on 7
Top Nova Development Computers & Internet Experts
Steve Nordquist
Steve Nordquist
David Shaub
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
