I've just installed an IOGEAR kvm switch. It worked fine for awhile but now I'm getting a ghosting effect with all the images and letters.
There can be a wide range of reasons causing this issue. It can be a bad cable, firmware issue or something else. You best bet is to go back to the supplier for support. I use KVM Switches all the time. I have purchased quiet a few CAT5 KVM Switch and IP KVM Switch solutions from KVMSwitchTech and they work great.
http://www.kvmswitchtech.com/rackmount-kvm-switches-c11580.htm
I would try with a firmware flash,...... this most of the time resolves issues with OSD issues.
Dear sir
good day
try to disconnect all of the KVM switch and
then try use one pc only and trace for the bad
cable ...
and if all are the same then you must go to the
warranty center and ask for replacing the KVM
thank you
Testimonial: "I don't think it is a simple matter of replacing the cables. I bought a Belkin KVM switch two weeks ago and it did the same thing. I have now bought a"
Are you using the same cable set? If so, then the first advice stil holds. If you are using completely different cables and switch, then suspect the monitor itself. Or possibly the video card is not pushing enough signal anymore (or too much) try a different monitor if you are able, and or a video card. The Narseman
