Question about Lexar JumpDrive Classic Portable USB Data Storage Device, 128MB. (PD0128231) Media
My usb is not being recognized when i put it in because either it is not updated or not working correctly? which one is it?
Posted by joshuarodrig on
  • MANUH Mar 11, 2010
    PEN DRIVE NOT RECOGNIZED
Anonymous
    Scholar:
  • 24 Answers
It sounds like your media is malfunctioning (controller issue).
Our company, LC Technology, is the only Sandisk-approved
data recovery company and we have been working on their products
for over 5 years. We service all brands. You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Lexar with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
[email protected]
1-866-603-2195 ext 103
LC Technology International
Posted on Feb 03, 2010
Colin
    Genius:
  • 1,584 Answers
Try clicking on My Computer / double click on / "C" drive and expand, can you see it there??
If not could be faulty mem stick.
Try in another PC, if it does work then probelm with Windows. I assume you also have the latest SP installed??
Posted on Dec 24, 2009
Chris Hingee
  • 32,281 Answers
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Posted on Dec 23, 2009
The USB ports (front and back) on my HP pavilion slimline s3500f, do not recognize any USB devices once plugged in. Device manager says the ports "are working properly" yet windows will not...
1. you possibly will need to update the usb drivers > Go to the 'device manager" and check the usb devices installed and update the drivers by right clicking and going to properties and go to update drivers.
Sep 12, 2011 | Computers & Internet
When i put my USB in CPU, the message display in my computer USB not recognized? This is philips webcom USB?
Try a different USB port. Try a powered USB hub (this camera can require more power than some ports provide). Check if the camera works on another computer (with the correct drivers installed). If it does work, continue with the steps below. If it doesn't work, unfortunately the camera isn't easily repairable. (The USB cable could have a damaged wire but you would need to fix it by desoldering the old one and soldering a new one. You would need to know the initial wire configuration before putting on the new one. Otherwise it is something wrong elsewhere on the board)
Enter the Control Panel > System > Hardware > Device Manager (for XP, it is similar for other Win OS versions). Scroll down to the USB controllers. Try to update the driver for this (right click and choose Update driver or double click and click Update driver).
Uninstall the current camera driver (including those for other cameras). Run a program like CCleaner.exe (scan for issues and then fix issues). http://www.ccleaner.com/ for this program which cleans the registry and other things. Download and install the latest driver for the Phillips webcam. http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=GB&slg=ENG&sct=WEBCAMS_SU&cat=WEBCAM_HEADSETS_CA&session=20101011130443_216.49.243.113&grp=PC_AND_PHONES_GR&ctn=SPC1000NC/00&mid=Link_Software&hlt=Link_Software .
I hope this helps.
Oct 11, 2010 | Philips SPC 1000NC/00 Webcam
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
USB not working
if the usb detects other devices and not your drive,the drive itself may be faulty.If you plug in other devices in the usb and it detects them the usb drive or its connector is most likely bad.If it won't detect any devices the port is bad and drivers won't help.Possibly a motherboard issue.
Oct 09, 2009 | HP Compaq nx5000 Notebook
USB PORTS
does your usb mem stick have any light indicators? if yes , whenever you put you usb stick, does it light? if it lights are USB ports is still ok,  You just have to reformat or partition you USB stick.
(you can also try other devices like usb mouse or any usb devices that lights up when you connect it)
if there are no lights if you plug, or no indication that a power goes to your stick, its possible that your usb your are busted. if this is the case, if your laptop has a PCMIA slot, you can find a pcmia USB card, if you dont have. your only option is replace the  motherboard.
Feb 01, 2009 | Averatec 3200 Notebook
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
Thinkpad T20 won't recognize usb port
You can get a PCMCIA adapter with 4 USB v.2.0 slots on eBay. It requires power from the USB port on the laptop, but the pigtail connector is included. Works like a charm! Comes from China just like everything else in this country.
Nov 16, 2008 | IBM ThinkPad T20 2647 Notebook
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
USB Ports not recognizing installed devices
did it come with xp pro or home? pro does'nt have the drivers that home doe's. use a home disk to update the drivers with
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 26, 2007 | IBM ThinkPad T42 Notebook
Lexar JumpDrive Classic Portable USB Data Storage Device, 128MB. (PD0128231) Media Logo
368 people viewed this question
Top Lexar Electronics - Others Experts
Lawrence Oravetz
Bill Boyd
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
