WILL THIS TV ACCEPT THE NEW DIGITAL SIGNAL - Televison & Video
Posted by odblder on
Joe Hogan
  • 10,865 Answers
Hello. All tv's accept the new signal. If you get your signal from satellite or cable, the box will make the signal compatible with your tv. IF you get your signal from an antenna, you may need a converter box, available from places like radio shack and staples.
Posted on Dec 23, 2009
Which HDMI Dongle is compatible with Sony Bravia KLV-32NX500 to make it a smart TV ? Please suggest.
As the HDMI input of TVs are only meant to accept video signals (to set HDMI specifications), any SMART TV dongle that attaches to the HDMI port is going to output a video signal compatible with the set HDMI specification. A modern TV like yours will be able to accept the digital video signal from any dongle, as it accepts all the common modern formats (1080p, 1080i, 720p, 576p, 576i, 480p, 480i)
Ref
https://www.engadget.com/products/sony/bravia/klv-32nx500/specs
Dec 23, 2017 | Sony Televison & Video
How do i see digital tv with my sony kp-53v75
If its an older set, it probably wont accept digital TV programs. You will need to get a set top box to convert the digital signal to work with your TV.
May 26, 2015 | Sony Televison & Video
How do I get my Panasonic CT-26WX15N to accept digital signals?
If you are using an older tv then yes you need a digital converter box to convert digital to an analog signal the TV can understand.
Oct 06, 2012 | Televison & Video
The SIGNAL: ANALOG won't disappear even though I've gone through the menu and selected my input OPT: CD/DVD/TV whatever it may be. How do I get my optical input recognized by the receiver? Is it broken?
It will change automatically once it detects a suitable digital signal.
So yes it could actually be faulty but more likely you aren't sending a suitable format digital signal from the source. check the digital audio output settings on whatever device you are using
old dvd players will output PCM 2 channel digital or bitstream multichannel (dolby dig or DTS) which your unit can handle whilst new blurays will have some very hi bit rates -eg192khz 24bit. You may need to lower the output in the menus to get the Pioneer to accept them.
It is always possible the optic has got kinked or fractured, which causes light scattering/corruption and will cause the same symptom
Sep 04, 2010 | Pioneer VSX-D411 Receiver
Digitial reception for casio 980
You won't. Because the unit isn't likely to have an coaxial external cable input, there is no simple way to achieve this. Full-size sets not equipped for digital signals can accept the down-converted signal from a converter box that receives the digital signal and converts it to NTSC standards for older sets. Direct reception of the new signal requires an ATSC tuner and there is no way to provide that for your hand-held. It would be possible to use the output of a converter box clipped onto the antenna of your Casio and see the channels the converter box can receive but your hand-held wouldn't be very portable anymore. Sorry-
Aug 20, 2009 | Casio TV-980 2.3 in. Handheld Television
When the digital requirements for the june 12 change came our new polaroid 15/19 inch flat screen tv would only receive 1 station clearly and the picture does not fill out the screen. What's wrong? It is...
Did you rescan your stations yet? When they made the transition, many, if not most, TV stations changed numbers on the dial. Enter the menu on your TV and manually tell it to rescan the stations. This should resolve the problem.
Jun 15, 2009 | Televison & Video
Cannot get my goodmans 289ns to accept the virgin digital signal
Will the TV go to channel 3? if not you need to reporogram the TV to sence channel 3 or go into the setup and undelete channel 3. Channel 3 is the channel your digital box is set to boradcast to the tv itself.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Goodmans 289NS 14" TV
Does Toshiba TiVo RS-TX20 accept the digital in February?
Any DTV Converter Box.
You Need a IR cable to control the DTV Box from the Tivo.
Repeat Guided Setup and select the correct DTV Box on the setup.
Jan 03, 2009 | Toshiba RS-TX20
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
