Question about Directed 2400d Car Audio Amplifier
Directed d2400 red and green lights on constant and no output...whats the solution
    New Friend:
  • 19 Answers
Ok ive had an orion amp do this before. oiron is made by directed audio now so its the same style amp. after i checked the ground, power, subs to make sure they were good and not shorted together, i came to the conclusion the amp was bad. its in protect mode right now so check everything with a multimeter and make sure everythings good. if all is ok the amp may be bad. good luck.
Posted on Dec 27, 2009
Directed d2400 turning onnot going on protected mode but sound on the output.needs resetting?
Just turn it on normally then after you verified that the green power light is on. And the protect light is on as well just one by one remove the fuses and then wait one minute not doing anything and just re install the fuses one by one and when the blue directed light reactivates (THE BLUE LIGHT ON TOP OF THE AMP COVER) you are good to go. Sometimes just removeing the amp trigger wire and reinstalling it will do the same thing. hope this helps. i do this on mine every now and again. Just wish i new what caused it to do it in the first place, this is just my solution to get it working again.
Apr 02, 2015 | Directed 2400d Car Audio Amplifier
2008 dodge ram speaker polarity
Here is the radio wiring.
2008 Dodge Ram 1500 Car Stereo Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Ground Wire: Black
Left Front Speaker Positive Wire (+): Dark Green/Yellow
Left Front Speaker Negative Wire (-): Dark Green/Light Blue
Right Front Speaker Positive Wire (+): Gray/Yellow
Right Front Speaker Negative Wire (-): Gray/Light Blue
Left Rear Speaker Positive Wire (+): Gray/Light Green
Left Rear Speaker Negative Wire (-): Gray/Dark Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
Jul 14, 2017 | Cars & Trucks
What colors are the left and right speaker outputs on a 98 4 door Accord
1998 Honda Accord Stereo Wiring Constant 12V+ White/Green Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Red/Black Antenna Glass Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Dec 23, 2010 | Car Audio & Video
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
I have a Directed D2400 amp and my red ESP is on
ESP ties the amp into your vehicle's alarm system. If the amplifier is working normally you can ignore the light. Note that this is NOT the protection LED for the amplifier.
Nov 04, 2009 | Directed 2400d Car Audio Amplifier
Pioneer deh-42 wiring diagram
Green: left front +
Green/black: left front -
Gray: right front +
Gray/black: right front -
Green/red: left rear +
Black/green: left rear -
Gray/red: right rear +
Black/gray: right rear -
Orange: constant 12v+
Red: switched 12v+
Black: ground
Blue: control output for amp or power antenna
Nov 02, 2009 | Pioneer DEH-425 CD Changer
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
No picture
When you turn it on if you haer a high chirp chip befor the light turns red
starter ok lamp has reach its life needs to be replcce
Mar 04, 2008 | Canon LV-7210 Multimedia Projector
Car Audio & Video Logo
302 people viewed this question
Top Directed Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ric Weide
Ric Weide
Level 1 Expert
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
