NorStar M7324 Telephone Logo
Anonymous Posted on Dec 23, 2009
I NEED TO FIND SOMEONE EXT.# WHEN THEY CALL ME IT SAYS THERE NAME BUT I NEED TO KNOW THE EXT#
george peters
Level 3:
President:
  • NorStar Master 860 Answers
  • Posted on Dec 23, 2009
george  peters
NorStar Master
Level 3:
President:
Answers
860
Questions
0
Helped
609272
Points
3471
You can either do a button inquiry in each of the extensions to see which extension number is associated with which name. that is done by going to each set and pressing feature *0 then pressing the intercom key. or you can look through set programming to find out.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Press the list soft key.
It will list the extension number followed by the name for the first extension.
Press the next key for the next extension (bottom right arrow) .
Press the release key when finished
How do i change the extension name on the display of NEC Dterm Series i?
Which NEC system is the Dterm Series i connected to? Normally you change the ext name in system programming, but I need to know which system it is.
2answers
Hi I have a Nec DT300 at work. I am on a new desk. Do you know how I can change the name which is on the display.
If you have the Admin password then follow this procedure:
For a DT330 (24-Button with 4 line LCD)
Do not lift the handset and press the Speaker button
Enter #*#*
Enter the 4 digit admin password and press the Transfer button
The phone will now display 'Program Mode'
Select Base from the four options using the associated softkey
Enter 15 and press the select softkey 2 times
The Extension Number and Ext Name will be displayed
Find the Extension Number you want to change the Extension Name for using the + and - softkeys
Press the Mic button to go to the Ext Name line
Enter the New Name using the number dial keypad.
If you make an error the Recall button will delete a character to the left and the Hold button will delete all characters to the right of the cursor.
Press the Transfer button to accept the new name.
Press the Answer button 4 times or until 'Program Mode' is displayed.
Press the Speaker button.
The system will save the changes and return the display to normal.
Is there a way to change the password on the phone system if you don't know the current password?
If you're talking about the voicemail for your extension, the person who is the voicemail administrator in your office can reset yours to whatever is default for your system. If you just got that ext and want to start fresh, and your ext doesn't own any additional mailboxes, have the administrator delete then re-add you mailbox, you'll be at default and can record your own name and greeting. If your ext owns extra mailboxes, don't delete the mailbox or the other mailboxes will also be deleted, such as the reception general mailbox, or the one that gives your companies greeting when someone calls at night. If your talking about the system programming password, that's typically a system tech thing and not given out.
2helpful
5answers
I'm unable to rename any file in win XP,a message appears "If you change a file name extension,the file may become unusable" Plz help
Go to control panel then go to folder option then click on view tab. On the list you'll find a option named "Hide extensions for known file type". Enable this option and click OK. Now you can rename your files easily.
I need to replace serpentine belt and need to know where the tensioner arm is and is there any adjustments to be made after replacing the belt on a 2005 trailblazer ext
It's on the left front, below the big pully. There is a square hole for a 3/8" breaker bar (just the breaker bar, no sockets) to fit in there. Turn it clockwise and the belt will come right off. There are no more adjustments. It's easier to have someone help you put the belt back on.
1helpful
I can't changed name on my phone. please help me.
The extension names can be changed in admin programming from a predesignated programming phone. Typically this phone is the attendant phone as in ext 100 or ext 101.This phone needs to have an LCD screen.
1) Press <program>
2) Dial **1234(1234 is the default admin password)
3) Dial 004 for Ext name programming
4) Press <enter>
5) Dial extension number that you want to change name of as in 102
6) Enter name (20 characters or less )
7) Press <enter> to store
8) Press <end> or lift handset and return to cradle to end programming session
2helpful
Panasonic KX-T7668 Name Display
I just managed to do this on my own phone.
Press programme button, enter programme number (**1234), using the up down arrows move to number 004 which should be xtension name. Press clear, to delete any information, then enter new name using keypad. When complete press enter in the middle of the up down keys, pick up and reset handset and it should be stored.
2helpful
2answers
Kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
40helpful
4answers
Change my display name
Mitel 420 superset
Message system does not work, system wide or just at your ext.? If it doesn't work system wide you have big problems. If it is only at your ext. your call forwarding maybe turned off. press superkey then press next til you see call forward and set it up. You Need to know pilot number to Voicemail.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
