We are trying to hook up one of our old vcr's (we used to have TiVo but needed to save money) and I have it hooked so that a video will play back on the tv but for some reason I can't get it to record from the tv. We have knology as our cable provider. I have it set up to record in the menu section....but it won't turn on and if I manually record, it won't record what I have it set to record....help!
The DLP does not have a flyback but if rear inputs work hook cable b o x there via audio/video cables or use a VCR (does not have to play tapes) via its av jacks to one set on back of tv.
If Video rear inputs are good but antenna,coax are not B Y P A S S the problem.
You can buy a used DirecTV with Tivo. You probably had a Hughes SD-DVR40 or SD-DVR80 before. The used model needs to be transferable to your account (which means it can't be leased, it has to have no outstanding charges on the previous account, etc). And you have to buy a new DirecTV card.
If you are in the San Francisco Bay Area or in San Jose, write to [email protected] and they should be able to help you out.
dont know how many times ive said this but GET AN OLDER TV it saves all that time you use trying to hook it up to a new one..it doesnt even have to be that old just not a plasma or HD tv, its much MUCH easyer and saves lots of time, and mabie even money
It seems to me that you have only got one set of RCA Cablec between the TV and VCR ( from VCR Video out to TV Video In), as such the VCR only works in playback mode, you need a second set of RCA cables (from TV Video Out to VCR Video In) then select the appropriate input (Video) for the VCR. make sure to follow the colour coding on the RCA plug / socket arrangement
Use the RCA connections of your TV to hook up the DVD/VCR, connect the "VIDEO OUT" of your TV to the "VIDEO IN" of the VCR and "VIDEO OUT" from your VCR to one of the video inputs of your TV. You need the double connection in case you want to record something to a VHS, otherwise, just hook up a cable from "Video OUT" of the VCR to any of the "Video IN" inputs of your TV.
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
For the best picture you can run RCA video and audio cables to the video and audio inputs on your VCR. Another way would be to connect your TV out to your VCR Ant in and then the TV out from the VCR to your TV. Tune your TV to channel 3 or 4 (set on the VCR) Turn on the VCR and you should see a picture. This should work without any problem. If it doesn't, then it is possible that your VCR has anti-copy firmware installed to inhibit or stop the copy process when triggered by a code from the program being aired. (GO Video has this) Many older VCR's do not. Try copying directly off the air or a commecial and see if your VCR can record that. If it can, then your VCR is equipped with a Macromedia Anti-piracy chipset and firmware. If it can't copy ANYTHING, then there is a problem with your cables or VCR. If you try replacing the cables with different ones, and it still doesn't work, then you VCR is defective and may require servicing.
