mY Dear: First: restore your Phone Settings IF Restart problem not Solved So Secend Option: Please Format Your Phone we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure. *#7370# or *#7780# Default security code is 12345 release some memory then it will b opened your phone or memory card get attack by virus. pls do a format phone and memory card. If Problem Not Solved So Very Best Solution: flash new software install in the phone problem will solved quickly
My Dear: First: restore your Phone Settings IF Restart problem not Solved So Secend Option: Please Format Your Phone we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure. *#7370# or *#7780# Default security code is 12345 release some memory then it will b opened your phone or memory card get attack by virus. pls do a format phone and memory card. If Problem Not Solved So Very Best Solution: flash new software install in the phone problem will solved quickly
this problem & restart problem is very common for 3110c,temperorily it can be fixed by changing the memory in use ,but for permanent fixing format the memory card ,if continuous with ame format the cell,hopefully formating the memory card will solve the problem
your card may need to be formatted for use in the phone. The phone supports FAT32 file system go to Menu - Tools/Setting - MemoryCard - Options - Format Mem Card and click YES
WARNING: Back up you card on your computer first because formatting you will lose your contents
Memory is used by pictures, text messages, and saved video. You need to clean out your Inbox on the phone, and delete any pictures and videos that are no longer any use. You can transfer to a laptop if you want before deleting.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
