Question about Fujitsu Siemens AMILO Pro V2010 Notebook
STEP 1.:-Turn off the laptop and remove the
battery.There are no screws securing the screen bezel. Start separating the
screen bezel from the display cover with your fingers.
STEP 2.:-Continue removing the screen bezel on
the top.
STEP 3.:Remove bezel from the hinges.
STEP 4.The
screen bezel has been removed.
STEP 5.:Remove six screws securing the LCD screen
assembly.
STEP 6.:-Separate LCD screen assembly from the
display cover.
STEP 7.:-Place
the LCD screen assembly face down on the keyboard. Now you can access the back
side of the screen and disconnect cables.
STEP 8.:-Disconnect the video cable connector
from the LCD screen controller board.
STEP 9.:-Parts of the video cable could be glued
to the screen. Unglue the cable.
STEP 10.:-Disconnect cable from the inverter
board.
STEP 11.Remove the LCD screen assembly.If you are
replacing the LCD screen you’ll have to transfer mounting brackets from the old
screen to a new one.
This will help. Thanks please keep updated.please do rate the
solution positively .thank you for using fixya
Posted on Dec 23, 2009
