you have to make sure if theres a bluetooth device installed to your computer
check in bios if its on/check also your specs from manufacturers website if your system came with bluetooth device because normally this model doesnt came with bluetooth device
in case your system came with bluetooth then you can download the drivers from this website
1) Install the bluetooth driver provided for your system. It will ask you to activate bluetooth by pressing fn+f2 key (this won’t work).
2) You manually have to install the software for the driver.
Note: some of you may have already installed the drivers but just cannot start the connection. So there is a problem in the software and not the driver.
For installation of the software follow these steps.
3) Go to your driver installation directory (ex. C:\dell\drivers) then you find which driver you installed for your bluetooth.
4) Then you find your system you are running (a 32 bit or a 64 bit) it will written as win32 or win64.
5) Then you find the installation file. Then install the application and it will be all ready once again.
P.s. don’t forget to turn your Bluetooth adapter on after you install the software.
i am using lenovo 3000 g430, and i am fall in problem about bluetooth, i am already install xp and vista, but when i install the bluetooth driver one warning message show me "bluetooth device not detected" my bluetooth device switch is on but indicator led light still off, please help me , how can i use bluetooth in this laptop.
Yes your Machine got WPAN: Bluetooth® 2.0+EDR (Enhanced Data Rate). If its not working then you need the drivers, you can download them free here If you problem was solved, Kindly do Rate!
Did it ever worked?
If you have never tried it before, it probably did not come with it. you can check to see if there is one already installed. It is is usually found near your ram. If it is there and and does not work, you can try to reload the drivers..if that does not work, it is probably fried.
