Kenmore refrigerator is not making ice,but water is connected ice maker control light is flashing
model 106.56879601
The control light flashes to indicate the infrared beam is being blocked. The flap on the opposite side blocks the beam when the door is open to prevent ice from being dropped on the floor rather than in the ice bin. If you pushe the flap in so it's flush with the liner (use care not to block the hole) the light should go from flashing to on in a steady state. If not, your electronics are bad and would need to be replaced. If the light does glow steady, then the problem is with your ice maker, water valve or ice maker fill tube.
