Question about Altec Lansing iM3 Computer Speakers
My Altec Lansing IM3 no longer works with the AC power adapter but does in battery mode. Does that mean I need a new power adapter or could the circuitry on the iM3 be faulty? I play this with my iPod.
  • Anonymous Dec 23, 2009
    Thanks, Fredy2.
    That was helpful.
    The voltmeter is a good idea. If it has power going through it, the adapter is probably OK and its the connection on the iM3 side. If that's the case,I'll just use it in battery mode when I travel because fixing the input jack on the iM3 side would cost as much as a new unit. thanks again.
Fred Yearian
  • 5,603 Answers
The power adapter could be bad BUT also the jack it plugs into may be bad. It will have a switch to disconnect the battery when adapter is plugged in.
You need to get a voltmeter and check the output of the adapter. OFTEN the cable beaks where it flexes. Sometimes the cable can be spliced, but DO be careful to not reverse the wires.
Posted on Dec 23, 2009
Testimonial: "Excellent and focused answer. Thank you."
AC adapter not charging system
check with multimeter on Volts DC if there is any voltage on Adapter pin, if there is no voltage then you need new adapter
Nov 28, 2013 | Altec Lansing Inmotion-IM600...
Power cord makes a chirping sound and won't supply power to M602. Do I need to buy a new power cord and if so where?
My experience is that when AC adapters start making strange sounds, they're no longer usable (or at least reliable), and need to be replaced.
I'd suggest calling Altec Lansing to see where you can get a replacement power supply.
http://www.alteclansing.com/
Feb 02, 2010 | Altec Lansing M602 (021986953371) Docking...
I have the IM3c portable speakers for ipod & adaptor head broke
Altec Lansing inMotion Audio Docks Mini Speakers eBay
Search eBay for low priced identical model if possible and purchase it to replace any broken parts.
Feb 20, 2018 | Altec Lansing iM3 Computer Speakers
Altec Lansing iM600
I have read the user manual for this product and it seemes to me you may have a defective battery.
Jan 13, 2008 | Altec Lansing iM3 Computer Speakers
Altec lansing iM3
Could be somthing wrong with the speaker.. Get a hair dryer and blow the air into the speaker its self. ods are you have gotten water or some liquid into the speaker its self and messed it up ... I would advise getting a new speaker for it or somthing =)
Aug 11, 2007 | Altec Lansing iM3 Computer Speakers
No power to speakers
Lol, sounds like that iPod sucked the power out of your house. Just kidding. If it is plugged into a wall outlet, make sure that the conections are not bent or warped in any way (remeber this stuff is very fragile so look for the smallest stuff). If it is plugged into one of those multi outlet devils, make sure that is not too clogged up. For those I always use the Male Bathroom Ediquate rule, never stand (nor plug) next to a guy in another urinal.
Jun 06, 2007 | Altec Lansing iM3 Computer Speakers
Power light is red
Get a new battery.. that one is shot.. it wont take a charge thats the reason bud
Mar 01, 2007 | Altec Lansing iM3 Computer Speakers
Altec Lansing iM3 Inmotion IPod Speaker system
have you checked the voltage requirement of the speakers?possibly, the voltage requirement of your speakers isn't adequately supplied by your batteries.if this is the case,please purchase the necessary batteries that would suffice the needs of your speakers.
Feb 02, 2007 | Altec Lansing iM3 Computer Speakers
Altec Lansing iM3 Computer Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
