Question about LeapFrog LeapSter L-Max Console
Question mark appears when cartridge inserted leapster
Question mark appears when cartridge inserted in leapster
Posted by juliawiese on
  • Anonymous Mar 30, 2014
    need to know how to get a cartridge game to work
Anonymous
    New Friend:
  • 63 Answers
Blow into the cartridge and blow into where you put the cartidge in there is most likely dirt inside those two areas.
Posted on Dec 23, 2009
Leapster restarts select cartridge game
Try this
Ensure that a cartridge is not inserted
Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
Aug 13, 2014 | LeapFrog Leapster 2 Learning System
Leapster2 is 2 1/2 years old. Placed brand new batteries in Leapster2. Try to power it on, screen comes up like it is going to turn on, and it turns off.
Welcome to FixYa!
Ensure NO GAME is in unit
Power Unit off
While turning Leapster 2 on, hold down HINT KEY. (Key in middle with question mark on left hand side)
Once unit switches to other menu, Hit A to begin calibrating.
Follow prompts with Sylas pen to reprogram Stylus pen.
Once you are done it will return to original Calibrating Menu.
Power Unit off Turn unit on with game inserted. Stylus pen should respond.
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Do comment if it helped or not in any manner ill know.
Apr 15, 2011 | Leapster 2 Handheld Game
When we inserted a new game cartridge (Pet Pals made for Leapster & Leapster 2) we get a question mark on the screen. We've changed the batteries and the old game cartridges are working fine. Please...
its not recognizing the game, contact is probably dirty. take an eraser and rub the contacts of the cartridge and get them super clean, blow out ALL the debris and that should fix it.
good luck!
Jan 29, 2011 | Leapster Learning System
My daughter has a Leapster 2 that is only about 2 months old and the touch screen does not work
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
5) Restart unit
Jan 30, 2010 | LeapFrog Leapster Learning Game System
Leapster will not work cartridges. A question mark appears on the screen when a cartridge is insterted
Thank you...Fixed it by bloing into the port and into the cartridge....seems dust may have affected it.
Dec 17, 2009 | LeapFrog LeapSter L-Max Console
Leapster pen not working
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
May 12, 2009 | Leapster Learning System
Our brand new leapster2 has
you could try this....
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Jan 21, 2009 | Leapster Learning System
The pen won't work on my daughter's leapster
Nov 10, 2008 | LeapFrog Leapster Electronic Book:...
LeapFrog LeapSter L-Max Console Logo
749 people viewed this question
Top LeapFrog Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Tom Chichester
Are you a LeapFrog Video Game Console and Game Expert? Answer questions, earn points and help others
