Question about Aqua GPS
I have an aqua vu scout and it has good battery and connection but no picture
Posted by mike61905 on
travelbobgau
    New Friend:
    Problem Solver:
  • 6 Answers
Mike if you are still having this problem, i figgured out how to fix it. i was having the same prob. so i cut the male conector part off the the camera cord and cut like 4" of the black cord part off to expose the wires. there will be 4 colored wires and 1 bare wire cut the bare wire off as close as you can to where you stripped off the black part, then expose the top inch of each color wire. OK now open up the back of the monitor, take the black female connector off you dont need it. you will see a 4 prong female connector part inside cut that off too, then conect the wires black - black / yellow - white / red - orange (i think it was orange) / blue - green . it sounds kinda complicated, but really easy, and now it works great! make sure you use electrical tape or something over bare wires
Posted on Jan 25, 2011
Screen and camera lite up, but why no picture and no focus?
Check your camera cable & 'FISH' camera for kinks,punctures, or tears. Reconnect the cable into the monitor. Have a nice day.
Jan 04, 2016 | Aqua Vu Scout SRT Fishfinders
My pal scout won't download from leapfrog connect it says error 400
I put in a new set of batteries and the data synced/downloaded to scout.
Mar 04, 2014 | LeapFrog My Pal Violet
It powers on but the screen does not turn on.never has worked since we bought it. called the teck service said that not possible so my buddy gave up on it.I put a new battery in it green lite comes on but...
Check the battery voltage. It should read around 12 volts. I have the same unit that did the same thing. The battery voltage was down to 6.5 volts. That was enough to power the LED but not enough to run the unit. Once I used a known good battery everything worked fine. Good luck!
Jan 21, 2011 | Aqua Vu Scout SRT Fishfinders
Lg vu...chrages and says battery full in a few mins, then has full bars...last all day for txting..but dies within 2 mins of talking
I have this same problem on one of my LG Vu's. New battery did not fix the problem. The charger is fine, because it works on my other Vu.
Feb 22, 2010 | LG Vu CU920 Cellular Phone
Will any 3V Lithium battery work for the Scout 1000 or does it have to be a specific amperage (power) rating or model?
Any good CR2 battery should work. Try this.....remove the battery cap, then pull out the spring a little bit, Dont break it. Make sure the battery goes in Positive end first. reinstall cap and see what happens. If you can, measure the battery voltage.(2.9 to 3.2 volts)
good luck
MTG
Jul 25, 2009 | Bushnell SCOUT 1000 Rangefinder
LG VU TOUCH SCREEN IS FROZE. CAN I GET PICTURES
Have you tried taking the battery out? And if that doest work you can call LG and they can replace your phone within warranty.
May 09, 2009 | LG Vu Cellular Phone
Aqua vu underwater camera
Aug 09, 2008 | Aqua -Vu Perch Underwater Camera with...
Need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Feb 17, 2008 | Cameras
GPS Logo
762 people viewed this question
Top Aqua GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you an Aqua GPS Expert? Answer questions, earn points and help others
