2003 Chevrolet Cavalier Logo
Posted on Dec 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Chevy cavalier wont start randomly! makes one click and a humm sound my lights come on the radio comes on but the car just wont start, ive had battery replaced along with the ignition switch, fuel pump, fuel filter, starter and alternator. sometimes it wont start for 5 min sometimes it takes hours to start, or i can go 2 weeks with it working perfectly or it wont start a few times a day! HELP PLEASE!!! ive spent a fortune trying to get it fixed and the mechanics i took it to said they couldnt help me...
Harvey N Tawatao
Level 3:
  • Chevrolet Master 3,854 Answers
  • Posted on Dec 23, 2009
Harvey N Tawatao
Chevrolet Master
Level 3:
Answers
3854
Questions
0
Helped
2794508
Points
16501
Ok then, from your description and the
make/model/year of the car you have there,
it appears you've reset the VATS.
The car's security immobilizer
reader at the key switch
does not recognize the coded
chip in the ignition key any longer.
You can try to put the key
in the ignition, turn to the on position &
wait at least 10 min like that.
(Do not turn off the key switch before
10 minutes as elapsed!)
Once done, the key is re-programmed and
should allow the fuel injectors to work again.
The car would start now if corrected.
In some cases, the VATS (GM'S VEHICLE ANTI THEFT SYSTEM)
will re learn the code this way, and will then
allow the restart, however if this does not work,
then you can simply tow it to any GM vehicle dealer
to have the service department re code it.
There is a permanent solution though.
Adding the PLJX Self learning Bypass module (59.95)
will bypass the PASSLOCK system in your vehicle
for good. See this at www.PASSLOCK2.com
Good luck I hope method 1 does the trick!
Here is the 30 min relearn:
Ignition keys relearn takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself.
1997 Chevy Cavalier z24. Theft Light blinks. Car will start for 2-3 seconds and then die. I read online and tried a few things but won't work. I turn the key so the radio and lights come on and left them...
Sounds like a dead battery. Clean the battery posts and terminals and charge it up. Then give it a try. If it starts go to auto parts store and get the charging system tested.
I have a 2004 Chevy Cavalier, the front end humms as I travel forward but the humming stops as I steer to the right, when I straighten out the humming starts again. Is this the CV axles going out? I...
the humming sounds like a wheel bearing problem cavaliers are notorious for the bearings going out i have changed many of them, i would change both front wheel bearings at the same time and not just one it will save you in the long run. hope this helped
4helpful
2000 chevy express 1500 van having starting issues
Start with fuel system. Listen for fuel pump humm at fuel tank No humm check wiring to pump for power. Then check for spark at plugs and wires. Remove wire from coil and hold near engine and see arch when you crank. No arch. Replace ignition Modular inside distributor cap or cap or rotor
1helpful
2000 Cavalier won't start, making fast clicking sound w/ ignition
Low voltage will cause the problem you are having,get the battery charged,and then have the alternator checked for the correct out put,13.65 to 14.25 if it is not in this range give or take a couple of volts,replace it,I would have the battery replaced also,so you won`t have the problem again.Have a shop replace the battery,if you do it yourself,the memory could be erased if certain measures are not performed.
1998 chevy cavalier wont start
Sounds like you are getting power to everything but the engine.
Was there a ground wire to the head that you may have left off ?
Hope this helps
Sam
1995 Z24 chevy cavalier wont even turn over...
obviously the altenator is running to earth inside ,could be a rectifier diode .change altenator and recharge battery
1helpful
System thelf light on car wont start 1996 chevy
Sounds like your security is staying on.Try locking the car with the remote keys then unlocking If that doesnt work lock car again and unlock it with key in passenger side door..These should solve your problems if not tell me what you got after doing those things..
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Start problems chevy cavalier z-24 1898
You would need to check to make sure you have spark coming from the coil. Make sure you have fuel spraying from the fuel pressure valve. Make sure the distributor cap is not damaged and you have the correct timing set for the spark plugs, consult owners manual.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
