For Tappan stove model 30-3053-23-02.
Each burner (4) is mounted to the stove top with three 4.5mm hex screws. All 12 screws must be removed, which is easier said than done. In my case, of the 12, 6 heads snapped off. The other 6 heads had to be drilled out. The metal is very hard (tempered from long exposure to high heat?), so use a carbide/diamond high-speed drill bit (1/8" or 3/16").
The front corners of the stove top are each held by a clip. After removal of the burner mount screws (or heads at least), lift straight up on each front corner of the stove top to release the top from the clip. An alternate method is to use a screwdriver as a lever to pry the corner off the clip. Once released from the clips, the front pulls up, while the back is "hinged" (like lifting an auto hood). Using a stubby phillips screwdriver, unscrew one of the back hinges. At this point, the stove top can be lifted off.
If you are fortunate, the burners were unmounted by simply removing the screws. But if they broke off or had to be drilled out, it seems the best thing to do is just purchase new burner assemblies ($20-$30 each). In either case, also buy new screws specifically for mounting the burners.
