Linksys Wireless-G WRTP54G Router Logo
Posted on Dec 22, 2009
Linksys wireless card unable to access
I started receiving the "Hardware ID missing" post when I try to open the Wireless G linksys application. I cannot access the internet via the card. While trying to uninstall and then install the software, I get the "system file not found". Anyone?
Anonymous
Level 1:
  • Contributor 72 Answers
  • Posted on Jan 04, 2010
Anonymous
Contributor
Level 1:
Answers
72
Questions
0
Helped
20326
Points
91
When you power on the wireless,its have some IP(like 192.168.0.1 or 10.10.1.1 something).
Just you ping the ip from your local set up PC.(*don't forget that your local PC is on same network)
If its ping properly then your wireless is good. otherwise problem is in wireless point
Link led keeps on flahing and act led is not coming only
Try resetting the Linksys router.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Linksys router unidentified network....receiving full signals but showing unidentified network ...i hv checked SSID and key both are correctly entered....
Try resetting the router and then configure it again.
http://192.168.1.1
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Have a WRK-54G Linksys wireless router. Have a
I had a TEW-421 card for a time, and it can not do WPA encryption, only WEP. It's not a driver shortcoming, it's the hardware in the TEW-421 card.
Sorry to tell you it's a dead-end, but at least now you know.
Hardware.ID is missing warning
The Linksys might not be compatible with XP sp3. If it was working before, there is nothing wrong with your Linksys
Cannot connect to wireless network
may be your router needs a firmware upgrade.
check the router's website.
and make sure the router and the wireless card are both using the same 802.11 protocol
Linksys router
The most direct way is to use the software to block by Mac address. Each computers card has a unique network ID that you can look up and then enter into your LinkSys.
Linksys Wireless N adapter Missing Hardware.ID
Hi Kathy,
Please do this first. go to control panel>add/remove programs, uninstall the Linksys Wireless N adapter.DO NOT UNPLUG THE WIRELESS ADAPTER FROM THE PC. Insert the Linksys wireless N adapter cd(DO NOT RUN THE SET UP). If the set up wizard shows up CLICK exit or cancel.Restart the pc with the disc in and the wireless adapter connected. When the pc boots up you will see the found new hardware wizard. Continue with the wizard, Select No not this time, Select install software automatically. If this is successful, your pc should be able to detect your wireless network
3answers
How to Configure D-link dwl-510 WiFi Card
To configure your linksys, access point, we need more information, the ipaddress oif your dlink router and the wireless settings on your dlink router..,
for more informations, check this link http:kb.linksys.com
for more details contact linksys; 18005465797
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
